Thread: How to check if Brake Servo is working correctly?
  1. How to check if Brake Servo is working correctly?
    Jan 2013
    newquay, cornwall
    Hello,
    Just a quick question,
    I need to find whats at fault with the braking system on my Golf MK3 TDI.
    I had the front brake pads replaced a few months back as the braking didn't feel too responsive, it's better now but still after braking once, the next
    time I go to brake straight afterwards the pedal requires more pressure?
    A mate bled the brakes and what not, and it was better.
    The car still brakes perfectly and everything, but I would like some advice on what everyone thinks it could be, before I take it to the
    garage and get it sorted.
    Could it be corroded brake lines?
    Servo Fault?
    If so, how could I check?
    Cheers!
  2. Re: How to check if Brake Servo is working correctly?
    Dec 2008
    Stockport
    More likely a flexi hose getting past it IMHO.
    If the servo isn't working the brakes are very solid (assuming the brake fluid system is OK) and hard to push. As a friend of mine said years ago, "It's like kicking a brick".
  3. Re: How to check if Brake Servo is working correctly?
    Jan 2013
    newquay, cornwall
    Hi BobProperty
    The fluid has been replaced and is all good, the brakes just aren't as responsive as I would want, but they're nothing like kicking a brick.
    How can I check if it's the 'Flexi Hose' that's the problem?
  4. Re: How to check if Brake Servo is working correctly?
    Pembrokeshire
    22 Post(s)
    the problem you have will be either a split vacuum pipe, a weak vacuum pump or a leaking servo. locate the pump on the engine block and follow the pipe to the servo, checking for leaks. if none are found, then a vacuum pump can be connected to the servo to check it is airtight and holding a vacuum. if this is ok, then the pump would be next on the list. you can measure the vacuum it draws and make sure its within spec.
    1 1 0
  5. Re: How to check if Brake Servo is working correctly?
    Jan 2013
    newquay, cornwall
    Thanks Zollaf, but what exactly does the pump look like?
  1. Question Is my multi box working correctly?
    By GolferPete in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-02-2010, 10:55 AM
  2. Please Help Indicators & temperature gauge not working correctly
    By fayraz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-12-2009, 10:12 AM
  3. A6 Avant 03 Rear wash working but not squirting correctly, Help?
    By Rockafella in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-12-2009, 02:57 PM
  4. Heating not working correctly( Its Cold )
    By folder in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-09-2008, 06:14 PM
  5. Electric mirrors not working correctly
    By Loofer in forum Chat - Anything with wheels
    Last Post: 24-09-2007, 05:55 PM
