Thread: Fault clearing ?
Results 1 to 8 of 8
  1. Fault clearing ?
    Jan 2011
    Stafford, UK
    2009 2.7 TDI A6 Avant, S-line, multitronic.
    I blew the 35A fuse that feeds the drivers side elec windows . I have renewed the fuse, cleared the fault codes but still have the one below. (03157 - Functionality limited due to Communications Disruption)
    Does this mean that something wants re-coding ?
    Sunday,05,May,2013,15:20:43:31033
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Address 5F: Information Electr. Labels: 4E0-035-6xx-5F.clb
    Control Module Part Number: 4E0 035 652 A HW: 4E0 035 652
    Component and/or Version: B-BN-EU H47 0048
    Software Coding: 010101010102C3FD43000F0DEF7300030001
    Work Shop Code: WSC 00779 210 97010
    VCID: 1F47CC660EC4E5E0386
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 55676 km
    Time Indication: 0
    Date: 2013.05.05
    Time: 15:13:56
    Freeze Frame:
    Bin. Bits: 00000000 00000000
    Bin. Bits: 00000000 00000101
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  2. Re: Fault clearing ?
    46 Post(s)
    Coding seems in tact:
    Go into VCDS - open Applications and press Erase All DTCs.
    Do a few ignition cycles and see if they reappear.
  3. Re: Fault clearing ?
    Jan 2011
    Stafford, UK
    I will try that Chris, thanks.
  4. Re: Fault clearing ?
    46 Post(s)
    No problemo, report back
  5. Re: Fault clearing ?
    Jan 2011
    Stafford, UK
    Still there Chris.
    I went into 5F - then 02 codes - showed 1 fault - erase codes, the fault code was erased but reappeared.
    I will drive it tomorrow and try it again.
    This was done with ignition on, engine off.
    This was the readout after I replaced the fuse & befor deleating the fault codes.
    Now all removed apart from 5F (in bold red)
    09 is OK - I have removed the fuse for the headlight washers.
    Sunday,05,May,2013,14:33:50:31033
    Chassis Type: 4F0
    Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F
    62 72 76
    VIN: WAUZZZ4F19N036857 Mileage: 55670km/34591miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    76-Park Assist -- Status: Malfunction 0010
    Address 01: Engine (CAN) Labels: Redir Fail!
    Part No SW: 4F7 910 401 K HW: 4F0 907 401 E
    Component: 2.7TDI EDC17G000CG 0090
    Revision: 16H01--- Serial number:
    Coding: 010D002C02070128
    Shop #: WSC 18432 423 592680
    VCID: 2B5F28B68A7C0940A4E
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4F5 910 157 H HW: 01J 927 156 JG
    Component: V30 0AN 2.7lTDI RdW 0010
    Revision: --H05--- Serial number: 00000000000328
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 2E5921A2B96E7C68830
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
    Component: ESP8 front H03 0060
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    VCID: 6DDBE6AE74E8C770FAA
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
    Component: FBSAUDIC6 ELV H05 0100
    Revision: 00H05000 Serial number: 10602601261827
    Coding: 0000147
    Shop #: WSC 02324 785 00200
    VCID: 254BDE8EEC983F3072A
    Part No: 4F0 910 132 E
    Component: FBSAUDIC6 EZS H03 0020
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
    Component: KLIMABETAETIGUNGH30 0070
    Revision: 00000073 Serial number: 00000000601444
    Coding: 0001302
    VCID: 1D3BF66EC4C8F7F02AA
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 N HW: 4F0 907 279
    Component: ILM Fahrer H22 0320
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013121
    Shop #: WSC 02335 785 00200
    VCID: 346D33CA574256B8F54
    Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H10 0040
    Coding: 00056595
    Shop #: WSC 02335
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00146221
    Shop #: WSC 02335
    4 Faults Found:
    00456 - Control Module for Access and Start Control (J518)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 30
    Mileage: 55608 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:00
    00061 - Footwell Lights
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00110111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 55608 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:00
    00910 - Indicator Lamp for Emergency Flashers (K6)
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 55608 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:00
    00924 - Relay for Headlamp Cleaning System (J39)
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 247
    Mileage: 55608 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:40:00
    Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
    Component: CDC-MP3-Pana H47 0050
    Revision: 00000012
    VCID: 2143CA9E38B0D3100E2
    Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
    Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 30314236303630303033554A305234463053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 30653FDA6B5A6A9891C
    Crash sensor for side airbag; driver side:
    Serial number: 3574SRB400008495215.
    Crash sensor for side airbag; passenger side:
    Serial number: 3584SRB40000849D397E
    Crash sensor for side airbag; rear driver side:
    Serial number: 35152RB402J838NMVR2V
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35252RB402P838NMV35H
    Crash sensor for front airbag; driver side:
    Serial number: 3554NRB40000491848A/
    Crash sensor for front airbag; passenger side:
    Serial number: 3564NRB4000049100D8W
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0530
    Revision: 00H05000 Serial number: 90055083440101
    Coding: 0102142
    VCID: 2757D48696942D20406
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 29
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:10
    Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
    Part No SW: 4F0 920 983 B HW: 4F0 920 983 B
    Component: KOMBIINSTR. H06 0135
    Revision: 00000000 Serial number: AE940E1D8
    Coding: 2F56110502002600010400
    Shop #: WSC 02391 823 56573
    VCID: 2B5F28B64A7C0940A4E
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0024
    Revision: 4LA70021 Serial number: 2100L0910680F4
    Coding: 000303
    VCID: 326135D26D565888E78
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0107
    Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
    Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
    Component: TSG FA H11 0250
    Revision: Serial number: 0000100632175
    Coding: 011F06205041410001
    VCID: 46897902F1DED4285B0
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:41:53
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:41:54
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
    Component: Komfortgeraet H27 0220
    Revision: 02200027 Serial number: 01166766660000
    Coding: 0140027
    VCID: 31633ADEA85063909E2
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 29
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:18
    Address 47: Sound System (J525) Labels: Redir Fail!
    Part No SW: 4F0 035 223 P HW: 4F0 035 223 P
    Component: BOSE G3 C6 H01 0100
    Revision: AG001300 Serial number: 00000000002161
    Coding: 0F010000
    VCID: 2953D2BE40801B50562
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H13 0100
    Revision: Serial number: 00000000610073
    Coding: 0001103
    Shop #: WSC 02145 785 00200
    VCID: DEB93162094E2CE8F30
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 30
    Mileage: 55608 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:00
    Freeze Frame:
    Voltage: 12.200 V
    Temperature: 77.0°C
    Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
    Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
    Component: TSG BF H11 0250
    Revision: Serial number: 0000100622308
    VCID: 458B7E0ECCD8DF3052A
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:17
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 1048575 km
    Time Indication: 0
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
    Component: EPB CEFC0090 H05 0090
    Revision: --H05---
    Coding: 0000531
    VCID: 2143CA9EF8B0D3100E2
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    VCID: 3F876CE66E0485E0186
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 053 B HW: 4F0 035 053
    Component: Radio U Basic H44 0020
    Revision: AB001007 Serial number: 341AQ097529712
    Coding: 010003010000000000
    VCID: 1C3DFB6A1FD2FEF8DD4
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 652 A HW: 4E0 035 652
    Component: B-BN-EU H47 0048
    Revision: -------- Serial number: 349A-097506098
    Shop #: WSC 00779 210 97010
    Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 245
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:43:13
    Freeze Frame:
    02259 - Information Display and Control Head (Front) (J685)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 30
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:53:47
    Freeze Frame:
    Voltage: 12.30 V
    Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
    Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
    Component: TSG HL H10 0251
    Revision: Serial number: 0000100645651
    Coding: 010E04204041220001
    VCID: 438F6016C2ECE1007CE
    Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
    Component: TSG HR H10 0251
    Revision: Serial number: 0000100645097
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:43:31
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:43:32
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4L0 910 283 A HW: 4L0 919 283 A
    Component: Parkhilfe 8-Kan H02 0400
    Revision: 00H02000 Serial number: 13630901502908
    Coding: 0201016
    VCID: 2855D7BA9B8A225849C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 30
    Mileage: 55609 km
    Time Indication: 0
    Date: 2013.05.03
    Time: 10:54:09
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Address 03: DTCs cleared
    Address 05: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 0E: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 42: DTCs cleared
    Address 46: DTCs cleared
    Address 47: DTCs cleared
    Address 4F: DTCs cleared
    Address 52: DTCs cleared
    Address 53: DTCs cleared
    Address 55: DTCs cleared
    Address 56: DTCs cleared
    Address 5F: DTCs cleared
    Address 62: DTCs cleared
    Address 72: DTCs cleared
    Address 76: DTCs cleared
    Chassis Type: 4F0
    62 72 76
    Readiness: 0 0 0 0 1
    Coding: 0000001
    Coding: 0020876
    Coding: 0000147
    Coding: 0001302
    Coding: 0013121
    Coding: 00056595
    Shop #: WSC 02335
    Coding: 00146221
    Shop #: WSC 02335
    Revision: 00000012
    Coding: 0102142
    Coding: 000303
    Coding: 0140027
    Coding: 0F010000
    Coding: 0001103
    Revision: --H05---
    Coding: 0000531
    Coding: 0000003
    Coding: 0201016
  6. Re: Fault clearing ?
    46 Post(s)
    Not sure Roy.
    If you go into the program directory of VCDS - on my Windows 7 it's:
    Computer
    C:
    Ross-Tech
    VCDS
    Debug
    You can see the changes that have been made to the coding - check if there are any differences in the coding.
    Only other thing I could suggest is to contact RossTech themselves and see what they say.
    Or PM bearthebruce on the forum as he works for RT.
  7. Re: Fault clearing ?
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Does your 5F still function ok? For a long (long) time my C6 had a fault logged in the 5F that would not clear:
    4F-Centr. Electr. II -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 5F: Information Electr. (J794) Labels: Redir Fail!
    Part No SW: 4E0 035 666 B HW: 4E0 035 666
    Component: H-BN-EU H64 0047
    Revision: -------- Serial number: 345BY097545942
    Coding: 010101000102C3ED01000315EF6300030001
    Shop #: WSC 00778 210 97003
    1 Fault Found:
    01043 - Control Module; Incorrect Software Version
    000 - -
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 136
    Mileage: 16274 km
    Time Indication: 0
    Date: 2009.11.11
    Time: 11:12:36
    Freeze Frame:
    Bin. Bits: 00000000 00010000
    It still functioned ok, and the dealer told me it was nothing to worry about. After a software update it magically righted itself:
    5F-Information Electr. -- Status: OK 0000
    Part No SW: 4E0 035 666 D HW: 4E0 035 666
    Component: H-BN-EU H64 0143
    VCID: 2756F15056F635B
    Subsystem 1 - Part No: 8R0 060 884 R
    Component: EUR 2010 1107
    Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
    Component: DU7 High H43 0306
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
    In short, I'd not be too worried if it is working ok.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  8. Re: Fault clearing ?
    Jan 2011
    Stafford, UK
    I haven't found anything that is not working, YET.
    It says "priority 6", Is this bad?
    Tuesday,07,May,2013,10:40:20:31033
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 247
    Mileage: 55682 km
    Time Indication: 0
    Date: 2013.05.07
    Time: 10:38:31
    Freeze Frame:
    I have found this -
    Number Meaning
    1 The fault has a strong influence on drivability, immediate stop is required.
    2 The fault requires an immediate service appointment.
    3 The fault doesn't require an immediate service appointment, but it should be corrected with the next service appointment.
    4 The fault recommends an action to be taken, otherwise drivability might be affected.
    5 The fault has no influence on drivability.
    6 The fault has a long term influence on drivability.
    7 The fault has an influence on the comfort functions, but doesn't influence the cars drivability.
    8 General Note
    The Reset counter is a number that has been pre-assigned to each fault, with the number of problem-free driving cycles before the fault presumably clears itself. Each time a driving cycle occurs, and the conditions sufficient to trigger the fault do NOT occur, then the reset counter should go down by one. So if you have a fault with a Reset Counter of 40, if the controller goes through a problem-free driving cycle then that number should go down to 39.
    My Reset counter: 247, I will have to see if it goes down.
  1. Please Help 2.0 16V ABF - not starting after clearing fault codes.
    By Roxy in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2013, 09:00 PM
  2. Will clearing the fault codes solve this problem VW Sharan
    By sharan1.9 in forum Touran - Sharan - Caravelle
    Last Post: 18-01-2011, 01:49 AM
  3. Question Cheapest method of reading and then clearing fault codes
    By yus786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-11-2010, 04:10 PM
  4. Help clearing code
    By bss1978 in forum VCDS - General Questions
    Last Post: 16-09-2010, 11:03 PM
  5. Fault code clearing
    By Nickleback in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 30-01-2009, 01:19 PM
