Thread: How to turn off seat belt chime with VCDS
  1. How to turn off seat belt chime with VCDS
    Mar 2012
    London, England
    Hi guys,
    I'm meeting someone to use their VCDS. I want to turn off the seatbelt chime, occasionally when I am driving, if I lean forward, the chime goes off, can be very annoying.
    So I just want to turn off the chime permanently via the VCDS. I have a 2006 A4 2.0T S Line Multitronic. From what I understand, some codes need to be changed, if someone can tell me how to do it for my car that would be great.
    Thanks.
  2. Re: How to turn off seat belt chime with VCDS
    Oct 2005
  3. Re: How to turn off seat belt chime with VCDS
    Mar 2012
    London, England
    Thanks, but to be honest I didn't understand it, can someone simplify this for me please.
    Code:
    Audi A4 (8E) Instrument Cluster (8E2/8E5/8H7)
    Contents
     [hide]
    1 Coding
     Coding
    00??xx1: Options +00 = 1. K-Number (Europe/USA/Rest of World)
     +01 = Smaller Fuel Tank Volume (All-Wheel-Drive)
     +02 = Seatbelt Warning (NAR old - up to 45/2004)
     +04 = 3. K-Number (Rental Cars)
     +08 = 2. K-Number (Australia)
    00xx?x1: Country 0 = Germany (D)
     1 = Rest of World (RoW)
     2 = USA (US)
     3 = Canada (CAN)
     4 = Great Britain (GB)
     5 = Japan (JP)
     6 = Saudi Arabia
     7 = Australia (AUS)
    00xxx?1: Seatbelt Warning 0 = No Seatbelt Warning (or NAR old)
     3 = Seatbelt Warning USA and Canada (NAR new)
    Main Page
    Fault Codes
    Diagnostic Procedures
    Control Module Maps
    Meta
    Log in
    Unless otherwise noted, all content on this site is Copyright © 2000-2010 by Ross-Tech LLC.  All rights reserved.
  4. Re: How to turn off seat belt chime with VCDS
    Oct 2005
    Turn ignition to ACC
    Connect VCDS cable
    Start VCDS
    Under Select Control Module click on Select.
    Click on 17-Instruments
    Click on Coding - 07
    Make a note of your current coding.
    Adapt the code so that the digit relating to Seatbelt Warning (ie the digit represented by the question mark in the massive load of text you've copied here) is a zero
    If you're not sure what you're doing, it's probably wise not to do it yourself.
  5. Re: How to turn off seat belt chime with VCDS
    Mar 2012
    London, England
    I've never used a VCDS, the user may understand it better.
    I don't mean to sound dumb but I still didn't quite get this bit:
    Do you mean that, whatever number is in place of that question mark, i should change it to 0?
    For example if the code is 0012341 then I should change it to 0012301
    Or should I change the number next to the ? Which would be the last digit. For example to 0012340
  6. Re: How to turn off seat belt chime with VCDS
    Oct 2005
    Quote Originally Posted by monz87 View Post
    Replace the question mark with a zero.
  7. Re: How to turn off seat belt chime with VCDS
    Mar 2012
    London, England
    Great, that seems straight forward. Thanks.
  1. seat belt chime
    By iain rice in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-07-2018, 02:30 PM
  2. How To How can I disable my Seat Belt Chime
    By Nick Collins in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-04-2012, 10:28 PM
  3. Question Seat belt chime
    By richiemac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-04-2010, 02:11 PM
  4. Please Help Seat belt chime
    By nileshdass in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-05-2009, 12:11 PM
  5. turn off drivers seat belt chime?
    By abt in forum The Commercial Range
    Last Post: 08-11-2008, 08:21 PM
