Thread: Audi Symphony Radio
Results 1 to 8 of 8
  1. Audi Symphony Radio
    Mar 2009
    Cheshire
    I have an Audi A6 2001 with the Audi Symphony Bose Radio / Cd / Tape / CD Changer unit.
    My problem is I need to disconnect the car battery to carry out some work on the car. My fear is that if I disconnect the battery once reconnected the radio will require the code which unfortunately I do not have as the previous owner removed the code card from the Radio manual and did not make a note of it anywhere.
    My question is as follows: Is there any way to keep power to the radio maybe via another supply / battery etc which would then allow me to disconnect the main car battery?
    Has anyone got any tips on how to do this? Maybe you have experience of this technique?
    Any advice would be appreciated?
  2. Re: Audi Symphony Radio
    46 Post(s)
    If its the original radio, you won't need to input the code again.
  3. Re: Audi Symphony Radio
    Mar 2009
    Cheshire
    Thanks A6_Chris, I had read this elsewhere and as far as I am aware it is the original unit. Is there any sort of time limit that the power can be removed from the radio? I guess the radio has a battery of it's own, is this how it retains the code?
  4. Re: Audi Symphony Radio
    46 Post(s)
    I think the serial code is matched to the car.
    if all goes wrong, audi will charge less than £10 to get the code.
  5. Re: Audi Symphony Radio
    Mar 2009
    Cheshire
    Ok thanks for your responses
  6. Re: Audi Symphony Radio
    46 Post(s)
    By the way, I replaced my Concert in my A3 with a RNSE a few months ago and I needed a CD out of the Concert, so plugged it back in and it came on straight away so if it lasts months, a few minutes will be fine.
  7. Re: Audi Symphony Radio
    Mar 2009
    Cheshire
    Just to update, when I removed the radio as A6_Chris suspected the code was not needed on re-installation. Makes a nice change for something to be simple with Audi's :-)
  8. Re: Audi Symphony Radio
    Jan 2012
    Coding Something
    The radio's remember the last vin plugged into & therefore no code is required.
  1. Please Help Audi 2003 Symphony Radio issue
    By dark_panda in forum In Car Entertainment
    Last Post: 10-10-2012, 10:49 AM
  2. MP3 Player and Audi Symphony Radio
    By B7Vic in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-12-2010, 06:01 PM
  3. Audi Symphony CD Radio Head Unit 6 Disc removal
    By allenmc2311 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-11-2010, 12:18 AM
  4. Audi Symphony Radio Broken
    By seanbrett in forum Audi A3 - Archive Topics
    Last Post: 30-04-2008, 01:36 PM
  5. Audi Avant A4 Symphony Stereo Radio failure
    By SimonVindec in forum New Member Introductions
    Last Post: 19-03-2008, 02:15 AM
