Thread: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
Results 1 to 10 of 11
  1. Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Nov 2012
    Somerset UK
    Reason I ask if have been offered a set of new Michelin Pilot Super Sports in 245/45/18 XL size at £450 that may be too good to pass up.
    They are going on Audi Ronal wheels.
  2. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Jan 2013
    Lincs
    Quote Originally Posted by MarkTM View Post
    You'll probably find the speedo is more accurate and the ride quality will be smoother.
    FWIW I would do it.
    2006 A6 Avant 2.7 TDI quattro S-Line
    2015 Q5 2.0 TDI S-Line Plus
  3. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Nov 2012
    Somerset UK
    DT,
    Soz do you mean more accurate with the 45's or with the original 40's?
    I thought all cars are calibrated to read more on the speedo than your actually doing, so at 40 on my speedo my GPS tells me I'm doing 38. More pronounced at 72 when GPS tells me am doing 68. So I take it your saying that the extra 5 may do away with this anomoly with the rolling radius increased just a smidge?
  4. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Jan 2013
    Lincs
    I believe so. Remember the 40 or 45 sizing of the tyre is a percentage of the width, so 40% vs 45% (IIRC about 12mm in your case).
    So 2⫪r means bigger circumference... so for a given engine rpm, for each revolution of the wheel you'll be travelling slightly further, therefore slightly faster.
    So you'll probably find you're closer to your GPS speed.
    I haven't done the calcs, so don't quote me
  5. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Nov 2012
    Somerset UK
    Will have to remember the increased accuracy if 'plod' stop me
  6. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Jan 2013
    Lincs
  7. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Nov 2012
    Somerset UK
    Great just bought them and collect Sat night
    Not bad reviews on them here:
    Michelin Pilot Super Sport | the Michelin Pilot Super Sport reviewed and rated | the online tyre guide
  8. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Jan 2013
    Lincs
    For £450 they're a bargain!!
  9. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Nov 2012
    Somerset UK
    Gup just gave me a link where you can compare current & upgraded tyres and it seems that 245/45/18's will make the speedo read 3.62% faster which should about address the deviation between speedo & actual ( also compared a smaller tyre)...if I'm reading it right Tire Size Calculator - Tire & Wheel Plus Sizing
    Apologies for the messy cut n paste below:
    Stock Tyre Size
    245/40R18 Imperial Metric
    Section Width: 9.65 in 245.00 mm
    Rim Diameter: 18 in 457.2 mm
    Rim Width Range: 8 - 9.5 in
    Overall Diameter: 25.72 in 653.20 mm
    Sidewall Height: 3.86 in 98.00 mm
    Radius: 12.86 in 326.60 mm
    Circumference: 80.79 in 2,052.09 mm
    Revs per Mile: 808.82/mi
    Actual Speed: 62.14 mph 100.00 kph
    Speed Variance: -
    Tyre Size 1
    235/40R18 Imperial Metric
    Section Width: 9.25 in 235.00 mm
    Overall Diameter: 25.40 in 645.20 mm
    Sidewall Height: 3.70 in 94.00 mm
    Radius: 12.70 in 322.60 mm
    Circumference: 79.80 in 2,026.96 mm
    Revs per Mile: 818.85/mi
    Actual Speed: 61.38 mph 98.78 kph
    Speed Variance: 1.24% too slow.
    -1.22%
    Tire Size 2
    245/45R18 Imperial Metric
    Rim Width Range: 7.5 - 9 in
    Overall Diameter: 26.68 in 677.70 mm
    Sidewall Height: 4.34 in 110.25 mm
    Radius: 13.34 in 338.85 mm
    Circumference: 83.82 in 2,129.06 mm
    Revs per Mile: 779.58/mi
    Actual Speed: 64.47 mph 103.75 kph
    Speed Variance: 3.62% too fast.
    Diameter Variance: 3.75%
  10. Re: Does anyone run tyres apart from 245/40/18 XL on 18" wheels?
    Leicestershire
    At that price can I get some too please?
    Audi A6 C6/4F 3.0 V6 TDI Quattro S-line - BMK
  1. Will 245 tyres fit my A6?
    By DukesA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-11-2010, 05:55 PM
  2. Brand New 19" Y Spoke Wheels + Tyres
    By rimap in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-05-2010, 10:50 PM
  3. Will 245/40/18 tyres fit 8" wide rs4 wheels
    By rhencullen1989 in forum Wheels and Tyres
    Last Post: 12-08-2009, 09:28 PM
  4. 18" Alloy wheels with tyres
    By Griff449 in forum Wheels and Tyres
    Last Post: 24-07-2009, 09:27 AM
