Thread: RE passat b6 + parking brake + esp + abs faults
  1. RE passat b6 + parking brake + esp + abs faults
    derbyshire
    hi all, a friends brother scanned in the faults on my 2006 passat 1.9tdi,
    the car drives fine but on the dash i have warning lights for parking brake, abs and esp, about 4 in total.
    i bought the car knowing it had these faults, i have omitted the stuff that doesnt contain errors.
    I am not using the parking brake incase it could damage any of the electronics
    The previous owner told me that he had the rear pads changed, if the change wasnt done properly could it cause these errors, also the previous owner used to work away for months at a time,
    perhaps i am clutching at straws but could a poor / flat battery cause these problems by damaging one of the control units. Could a flat battery cause the control units to loose the settings if the car was left standing for months with a flat battery
    I am going to jackup the rear of the car at the weekend and check the calipers to see if i can see any obvious sisgns of tampering then possibly change them if i can get my mates brother to come back over. Then going to remove the abs module and get it tested or is there any way of checking the abs control unit in situ
    this is the read out, i have removed the bits that dont contain faults
    Address 01: Engine
    Labels: 03G-906-016-BKC.lbl
    1 Fault Found: 006215 - Please check DTC Memory of ABS Controller
    P1847 - 000 - Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 215622 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 10:49:02
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    (no units): 3.00
    Voltage: 11.93 V
    (no units): 0.00
    Bin. Bits: 00000011
    (no units): 8.15
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes
    Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 P
    HW: 3C0 614 095 P
    Component: ESP 440 C2
    H015 0003 Revision: H015
    Serial number: 0667248147
    Coding: 0010000
    4 Faults Found: 01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 215622 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 10:49:10
    01423 - Lateral Acceleration Sensor (G200)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 215622 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 10:49:10
    01279 - Longitudinal Acceleration Sensor (G251)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 126
    Mileage: 215622 km
    Time Indication: 0
    Date: 2013.03.26
    Time: 10:49:10
    00810 - Sensor 1/2 for Brake Pressure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 126
    3 Faults Found: 01316 - ABS Control Module
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 127
    Mileage: 215288 km
    Time Indication: 0
    Date: 2013.03.25
    Time: 06:59:52
    freeze Frame:
    Voltage: 10.46 V
    Count: 236
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 124
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.87 V
    Count: 171
    01087 - Basic Setting Not Performed
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 8
    Reset counter: 124
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.87 V
    Count: 170
    VCDS Self-Diagnosis Log Thursday,04,April,2013,14:59:52:32264 Page 9
  2. Re: RE passat b6 + parking brake + esp + abs faults
    Feb 2009
    Got the same problem with one that has same abs module battery flat lost coding in abs if you change coding 0000000 it will just show wrong coding and other faults will be gone
  3. Re: RE passat b6 + parking brake + esp + abs faults
    Feb 2009
    Got it sorted code ooo1298 worked
    also tried 0001288 from another diesel passat might work for someone else
  1. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  2. Please Help 2003 Passat 1.9 TDi Brake and Clutch Problem - ESP and ABS lights on
    By Stuartd77 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2011, 09:20 AM
  3. ABS ESP and Over-Revving Faults!!!!!!!!
    By TDIDave130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2010, 04:50 PM
  4. Please Help Passat 2.0S 2002 Brake Lights and Flat Battery with intermittent ESP / ABS warning light
    By tweever in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2009, 01:50 PM
  5. 2008 A6 MMI and Parking Brake Faults
    By MClarke in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-08-2008, 12:25 AM
