Thread: Front fog covers/lower grills how to remove?
  1. Front fog covers/lower grills how to remove?
    Jul 2011
    Dundee, Scotland
    I have had my A6 2010 (facelift) Le Mans for a few weeks now and noticed the fog light covers and grill part on the front bumper dont seem to be fitted correctly.
    There is a flexible plastic cover that seems to be unclipped but cant work out how to remove the black foglight plastic surround to fix it.
    Does the front bumper have to be removed to get at that?
    or does the fog surround unclip?
    thanks in advance,
    Sammy
  2. Re: Front fog covers/lower grills how to remove?
    46 Post(s)
    On my A3 if you give them a good pull they will come off.
    Also there should be a little cutout on one of the slats to grab from.
    Sent from my iPhone using Tapatalk 2
  3. Re: Front fog covers/lower grills how to remove?
    Feb 2009
    Glasgow UK
    Hey there, Chris is pretty much spot on with his description tbh
    If you look at either sides of the housing there are little tabs that slot into corresponding slots on the bumper. Simply using perhaps a flexible knife or similar in conjunction with a cloth, insert the knife into the ends and wedge it away from the bumper......once one end is out it can simply be removed to allow access.
    Just for info, these parts can be bought from the dealer for around £9 the pair, at least that what I bought them for a year or two ago, cheap as chips.
    Good luck
  4. Re: Front fog covers/lower grills how to remove?
    Jan 2011
    Stafford, UK
    Yes, just pull them off.
  1. 2008 A4 TDi Front Fog Light Grills
    By balders77 in forum Body Work, Body Styling and Body Kits
    Last Post: 21-03-2013, 08:34 AM
  2. B7 Fog light Grills
    By phantomdox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-12-2010, 05:12 PM
  3. Replies: 1
    Last Post: 11-12-2010, 08:01 PM
  4. Question Golf Mk5 front fog light Grills do they fit
    By baz2236 in forum Jetta MK3 - 2005 - 2013
    Last Post: 26-02-2010, 11:17 AM
  5. front lower grills
    By mark78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2008, 10:15 PM
