Thread: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
Results 1 to 10 of 12
  1. 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Nov 2012
    leeds england
    according to Honest John, not seen it posted here, any one aware of this etc ???
    S5 3.0 tfsi drive select dampers sports diff nav bang stereo keyless heated seats privacy glass tech pack
    SOLD A4 B8 Quattro S line 3.0TDI saloon in white "Horsepower sells cars. Torque wins races" -Enzo Ferrari
  2. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    46 Post(s)
    In the 4 years I've been on this site I haven't seen anything regarding to it tbh.
    Sent from my iPhone using Tapatalk 2
    1 1 0
  3. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Pembrokeshire
    22 Post(s)
    if honest john says so, then it must be true.
    mind you, most of the drivel i have seen on that website is complete hogwash.
  4. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Nov 2012
    leeds england
    thanks for the reasurrance guys
  5. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Oct 2009
    Malvern
    Well I had a problem with my EGR valve, I was using water a pint every 300 miles, luckily it was sorted under the warranty, It turned out to be a crack in the EGR valve casting ;-(, took Audi three visits before they found the problem? I was convinced it was a cylinder head problem, luckily it wasn't.
    Audi A4 3.0TDI Q SE Lava Grey + B&O, Audi Drive Select, Sports Seats, Sun Roof, DVD Sat Nav Plus, Blue Tooth Phone Prep, Audi Hill Assist, Rear Parking Aid, Electric Seats, Light Pack, Audi Audio Interface, MMI etc... and 4 Halfords Bulbs lol....
    2 0 0
  6. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Pauls898 View Post
    Do you mean the cooling flap unit or cooler... as the EGR valve does not have coolant running through it...
    BTW I'm not losing coolant just wanted to know for memory bank as have an A6 Avant V6 3.0 TDi (same engine/design)...
    Regards
    G
  7. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Oct 2009
    Malvern
    Hi gupsterg
    The part which the Audi technician showed me looked to me like a small model steam engine boiler, there were lots of small holes where the exhaust gases past though, this was surrounded by a water jacket to cool it, it had two halves so for each bank of 3 cylinders gases to past though, the one half was all black and sooty the other side was all clear, i.e. steam cleaned by the water leaking and passing though clean it as it went. Once this part had been replaced the water usage stopped ;-) They said it was called the EGR Valve and on the V6 models, yes the water does pass through it to cool it down. Hope this helps.
  8. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Sep 2012
    Bristol
    Hi guys,
    I've got an Audi A6 3.0 TDI Avant (58 reg) 70000 miles on the clock, and I am slowly loosing coolant liquid. Half a pint every 2000 miles. Yesterday I saw my friend, he is a car mechanic and runs his own garage. We spent a good 30min trying to localize the leak and finally he found coolant liquid deposits under the EGR. Difficult to see through all those pipes and hoses, but it was definitely there,collecting onto the passenger side bank. He could not localize the exact spot where the coolant was leaking from, and we didn't see any stream of coolant running. So he is going to get a new coolant pressure pump (his current one is broken), and then he will remove as many parts from the top of the engine as possible and try to localize the leak. As I I said, it is under the EGR and it is an external leak. He is betting on one of the EGR cooler hoses (fingers crossed) or it could be an oil cooler leak (small oil cooler sits between the banks, so I was told).
    So wish me (and him) luck to find the culprit and post some suggestions if you have any.
    I will keep you posted.
    Martin
  9. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Jul 2010
    Edinburgh
    I think it is a known issue. I have a B8 2010 3.0TDI V6 and my water pump failed when 8 months old and about 14,000 miles. This was the thread about it at the time and Audi were well aware of it:
    water pump failure
  10. Re: 3.0TDI V6 quattros prone to water pump failure and also prone to losing coolant from the water cooled EGR valve.
    Sep 2012
    Bristol
    Hi guys, so I have an update to what seemed to be a EGR valve cooler leak.
    As it turned out yesterday, it was actually a banjo bolt on the left (passenger) bank leaking, with coolant collecting under the EGR cooler. Hence the suspicion for EGR leak.
    If you look at the left picture, there is a T piece in the coolant hose (marked with blue), from which another hose is running down to the left engine bank. The hose then connects to the metal pipe (second picture, with the part number) and the metal pipe is then bolted with the banjo bolt to the engine block (left bank). The banjo bolt is located well below the swirl flap mechanism.
    It was really difficult to locate the leak. I was with my mechanic at the time and we luckily spotted just one drop running down the left bank under the banjo bolt, when the coolant system was pressurized. A bore-scope camera has helped a lot as there are many pipes, hoses and cables blocking the view.
    We decided to change the metal pipe, all the washers, clips and the banjo bolt, together with a short coolant hose running from the bottom of the EGR cooler to the engine block. Parts cost £38 and my mechanic charged £120 for the labor. Given the amount of things that had to be removed to get to the banjo bolt itself, I can't complain about the price.
    So I will monitor the coolant level and will keep you posted.
    Hope this post will help other forum members with similar problem!
  1. Are modern diesels prone to failure
    By shahid1973 in forum Bora - 1998 - 2005
    Last Post: 18-08-2011, 07:50 PM
  2. Is the 30V V6 Prone to bottom end failure?
    By beelzibus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 02-01-2010, 02:18 AM
  3. Is the PD 115 engine prone to head gasket failure?
    Last Post: 18-04-2009, 01:41 PM
  4. Losing Coolant Golf 2.0 GT TDI 140 (EGR Valve)
    By felinus in forum Golf MK5 - 2004 - 2009
    Last Post: 27-01-2009, 11:39 PM
  5. Is the EGR valve water cooled
    By chrisvrscrx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2007, 08:13 PM
