Thread: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
Results 1 to 8 of 8
  1. 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    Jan 2013
    Lincs
    I've been searching the forum without success.
    I checked the RT Wiki and tried to perform the Basic Setting on 142 but it failed and block 4 stayed in ERROR.
    Can anyone give me any pointers with these two faults please?:
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
    Component: 2.0l R4/4V TFSI 0030
    Revision: --H10--- Serial number: VWZ7Z0E2975451
    Coding: 040300031C070160
    Shop #: WSC 00222 210 89998
    VCID: 2D51C4FAB4F2A470BAA
    2 Faults Found:
    012691 - Intake Manifold Runner Control
    P3193 - 002 - Open Stop outside of Valid Range
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 105431 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:22:09
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 6.0∞C
    Temperature: 7.0∞C
    Absolute Pres.: 1010.0 mbar
    Voltage: 11.811 V
    004248 - Intake Manifold Tuning Valve Position Sensor (G336)
    P1098 - 001 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 105431 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:22:09
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 6.0∞C
    Temperature: 7.0∞C
    Voltage: 11.811 V
    Readiness: 0110 0101
    Many thanks and sorry if I missed the info elsewhere.
  2. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    UK Ex-pat now in Australia
    I believe there is a Technical solution from VW that says to replace the intake flap motor.
    Had MKV GTI, Now Ford Falcon
  3. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    Jan 2013
    Lincs
    Quote Originally Posted by -M- View Post
    Thanks for the reply! I thought that was the case, but the only examples I could find had different fault codes, some of the terminology used (depending on country) also threw me off a bit
    Have you any experience of changing the flap motor?
    Thanks again.
  4. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    Its not the nicest of jobs due to the tight space.
  5. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    Jan 2013
    Lincs
    I've been looking at Elsawin and from the description the job sounds a PITA
    Any top tips to share? (other than pay someone else )
  6. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    You have to be very very careful when seperating the linkage from the ball and socket arrangement. The best way is to remove as much as possible to allow better access. I'm not sure but iirc you may need a very long socket extension to reach the bolts/screws from underneath.
  7. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    Jan 2013
    Lincs
    Many thanks!
    All tips gratefully received
  8. Re: 2006 GTI Intake Runner Control (with VCDS Fault Codes)
    Feb 2014
    A, A
    Hi ,just searching through here as I have the same Intake Manifold Tuning Valve Position Sensor error on my golf 1.6 Fsi. How did you (eventually) solve your problem? Any tips would be great as I am keen to find out whether a trip to a vw dealer is worthy or not.
    Thanks !
    2 Faults Found:
    17503 - Intake Manifold Tuning Valve Position Sensor (G336)
    P1095 - 001 - Short to Plus - MIL ON
    16575 - Fuel Pressure Sensor (G247)
    P0191 - 002 - Implausible Signal - MIL ON
    Readiness: 1010 0001
  1. Please Help Intake manifold runner control fault
    By A3Quattro in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-09-2014, 04:51 PM
  2. help with vcds fault codes
    By chrismk5 in forum VCDS - Help Requests
    Last Post: 15-06-2012, 05:43 PM
  3. Intake Manifold Runner adaption
    By big in forum 2.7TDi - Engine
    Last Post: 25-04-2012, 09:35 AM
  4. Intake Manifold Flap Fault Codes and Cleaning
    By aceofharts414 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-11-2010, 09:44 PM
  5. Intake manifold runner control basic setting
    By grabread in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 02:02 PM
