Thread: MMI VCDS Fault code post flood/software update
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. MMI VCDS Fault code post flood/software update
    Jan 2013
    Lincs
    Hi all
    Have had a mini flood under the pax side carpet which has written off the bluetooth module (many thanks to Gup and his epic thread: The most Lemon Audi A6 Avant strikes again as I had the same problem)
    I only discovered this when an attempted software update went wrong...
    Anyway BT module now disconnected and a MOST bridge fitted, but MMI still a bit buggy and VCDS has given me this fault:
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 S HW: 4E0 035 729
    Component: Interfacebox H43 5150
    Revision: 00000000 Serial number: 350CW067665658
    Coding: 0001002
    Shop #: WSC 02335 785 00200
    VCID: 3365D28252D6F280ECE
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H03 0050
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 90427 km
    Time Indication: 0
    Date: 2013.02.02
    Time: 19:01:09
    Can anyone help me on this one (the frequency is low as I cleared all faults last night)?
    Many thanks
  2. Re: MMI VCDS Fault code post flood/software update
    46 Post(s)
    have you unticked telephone in the can gateway?
  3. Re: MMI VCDS Fault code post flood/software update
    Jan 2013
    Lincs
    No
    I'm a total noob, only got VCDS yesterday...
    I'll look it up.
    Many thanks
  4. Re: MMI VCDS Fault code post flood/software update
    Sep 2011
    Lurking over a keyboard ...
    When you go into module 19 click on the "Installation list button" then you just uncheck relevant box & save...
    Ross Tech have a good wiki as well... Link:- Audi A6/S6/RS6/allroad (4F) - Ross-Tech Wiki
    Here another good link:- Ross-Tech: VCDS Tour: Gateway Installation List
    Another great site Link:- Audi Portal: ECU Diagnostic . Without address word
    Quote Originally Posted by DieTryin' View Post
    Coding: 0001002
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 90427 km
    Time Indication: 0
    Date: 2013.02.02
    Time: 19:01:09
    When Audi did not code my ECU correctly my ECU showed an error... maybe due to the flashing hiccup you are having this error ...
    If it does go away after editing the CAN gateway all good if not maybe a comparison with members concerning your codings/adaptations?
    1 1 0
  5. #5
    Jan 2013
    Lincs
    Right, I'm on it - MANY thanks!!!
    I'm not sure which is most embarrassing, buying a car that has a distinct whiff of citrus fruit about it, or coming on here every 5 minutes pleading for help.
    Sorry and thanks!!!
  6. Re: MMI VCDS Fault code post flood/software update
    Sep 2011
    Sorry and thanks!!!
    Don't worry mate mine is as zesty fresh as yours ... I think I would have been carted off by the men in white coats if it wasn't for the support here ...
    1 1 0
  7. Re: MMI VCDS Fault code post flood/software update
    Jan 2013
    Lincs
    OK, removed item 77 'phone from the CAN gateway list, re booted MMI then re-scanned the Control Head and the fault remains:
    1 Fault Found:
    Freeze Frame:
  8. Re: MMI VCDS Fault code post flood/software update
    46 Post(s)
    clear it from the application menu when you first start vcds .. applications - erase all dtc's
  9. Re: MMI VCDS Fault code post flood/software update
    Jan 2013
    Lincs
    I've done as you described (phone wasn't in the list), but fault remains....
    Thanks for the suggestion though!!
  10. Re: MMI VCDS Fault code post flood/software update
    Sep 2011
    IMO you need to double check the coding/adaptations in module 07...
    You can build up coding/adaptations or check if they are correct in there by cross ref'ing the info in the VCDS wiki...
    Link:- Audi A6 (4F) Control Head Front (High) - Ross-Tech Wiki
    Post some screenshot's perhaps of coding/adaptations in module 07?
    I was doing the software update today; running Disc 2, but before it was finished I had a small domestic drama and had to start/drive off in the car....
    From what I remember disc 2 only does the BT units... so if disc 1 finished correctly all should have been done AOK to v5150...
    You can see in your VCDS log that 5150 update has been done...
    Only if you feel comfortable if I was in your shoes you could run disc 1 of MMI update again... it will only apply updates if they need to be applied...
    I'll have a scan later of MMI FW 5570 Disc 2 content later unless someone else is able to post you some info...
    Do make sure all elec.connections are dry... before doing any update!
    1 1 0
  1. MMI 2G High 5570 Software Update Discs
    By A6al in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2012, 12:38 PM
  2. MMI 3G Software Update
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-06-2012, 03:14 PM
  3. MMI Software update?
    By Yowfailed in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-02-2012, 08:13 PM
  4. VCDS faults before MMI update
    By piotrek in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-04-2011, 01:13 PM
  5. Concert radio software update without MMI
    By ktulu in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-09-2008, 10:00 PM
