Thread: ElsaWin
Results 1 to 8 of 8
  1. ElsaWin
    Mar 2009
    Cotes d"Armor, France
    I would like to use Elsawin & VagCom but my computer is a Mac. I have an old laptop running Windows 7 that I keep in the garage with motorcycle manuals on. I've read that ElsaWin wont run on Win 7 and that XP is the last version that will run it.
    Can anyone confirm this please before I run out and buy XP for the laptop.
    `05 1.9 TDI 130 Avant Multitronic - 4B5 06H - AVF HB9 Final Edition
  2. Re: ElsaWin
    Oct 2005
    ElsaWin is dealer only software.
    1 1 0
  3. Re: ElsaWin
    46 Post(s)
    You can run VCDS through a VM using Paralells or Bootcamp.
  4. Re: ElsaWin
    Mar 2009
    Thanks I've considered that but my iMac's a bit heavy to lug into the garage for the VCDS. I wondered if elsawin would fit on with bootcamp though, does it run XP programs?
  5. Re: ElsaWin
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by ellaguru2u View Post
    Elsawin 4.0 runs out-of-the-box with either 32bit or 64 bit Windows7 with no issues.
    VagCom I believe only runs under 32bit Windows7. If you are running a 64 bit Windows7 laptop, you need to setup a "virtual XP" partition which runs as an application under the 64bit Windows7. SW updates available from Microsoft website. When setting up the virtual partition you have no choice - you get Windows XP installed. You then install VagCom in your XP System. This facility is positioned by Microsoft as a "migration platform" for 3rd party apps where the developers could not be ars*d to produce Windows7 support. Virtual XP is rather slow to boot up but thereafter seems to run ok. Not sure if it can keep up with VagCom continuous logging, but that apart should be ok. My VagCom runs under native 32bit Windows7.
  6. Re: ElsaWin
    Mar 2009
    Thanks for that I'll have another look at bootcamp
  7. Re: ElsaWin
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by ceilidhalfie View Post
    Sorry to mislead you. VCDS runs fine under Windows7 32 or 64 bit. You need to change the VCDS "Properties" to run in Compatibility Mode (XP Service Pack 3) and then run as normal.
  8. Re: ElsaWin
    Mar 2009
    Thanks for that, my old laptop is struggling a bit, loosing steam I think. I might surf Ebay for a replacement (with XP)
  1. elsawin help!!!!!!
    By burkey1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2011, 12:46 AM
  2. Question Elsawin
    By Gary.Townend in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2010, 10:30 AM
  3. Question ElsaWin 3.7
    By Meds in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2010, 02:09 PM
  4. Question elsawin 3.7
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2010, 07:50 PM
  5. Elsawin
    By harris921 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 15-05-2009, 10:59 AM
