Thread: AWX or AJM engine??
  1. AWX or AJM engine??
    Mar 2007
    nr Gloucester
    I was just having a look through an old scan and noticed that the label on the engine ends with AJM. My car is a 1.9tdi 130 (i hope!). Scan below...
    Address 01: Engine Labels: 038-906-019-AJM.LBL
    Controller: 038 906 019 JT
    Component: 1,9l R4 EDC G000SG 1572
    Coding: 00002
    Shop #: WSC 63351
    VCID: 7297B3E62DA1
    WAUZZZ8E63A241171 AUZ6Z0B0343816
    No fault code found.
    Readiness: N/A
    How does that read to someone in the know about these things. Is the engine in fact an AJM - 115 or AWX which the cam cover label says?
    It is worth mentioning that my car was cat c.
    TIA
    Audi A6 (C7) 3.0 BiTDi Black Edition 2016
  2. Re: AWX or AJM engine??
    Aug 2011
    Meath
    There should be a label in the boot as well
  3. Re: AWX or AJM engine??
    london/ UK
    AJM was only fitted to audi a4 b5 and passat b5 from 2000 V,X and W reg. No b6 audi a4 came with AJM engine but they had a AVB which is 100Bhp. If the cambelt cover sticker said AWX then it's 130Bhp. Check the service book sticker for the reight engine code...
  4. Re: AWX or AJM engine??
    Mar 2007
    nr Gloucester
    Thanks for your replies. I'm just thinking the engine could have been swapped out by a previous owner, maybe me just being paranoid as the car has been in a smack. I just thought the engine label would be AWX that was all.
  5. Re: AWX or AJM engine??
    7 Post(s)
    The AJM engine reference is only the VCDS label file reference by the looks of it.
    The label file in VCDS adds labels / desriptions to measuring blocks and the like.
    I wouldn't worry and as above, check the boot sticker and or the cambelt cover where you should see your AWX engine code.
  6. Re: AWX or AJM engine??
    Mar 2007
    nr Gloucester
    Fair enough. Panic over!
  1. Audi A4 AJM TDi engine into my AJM MK4 Golf??
    By Digidick in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2012, 11:34 AM
  2. Torque on AWX vs AVF vs AJM
    By itssmail in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2010, 12:03 PM
  3. ajm engine trouble
    By a41.9tdiajm in forum New Member Introductions
    Last Post: 15-10-2009, 10:23 PM
  4. A4 1.9tdi SE 2OOO yr engine AJM
    By andymccartney in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2008, 02:35 PM
  5. A4 Tdi 1.9 Ajm Engine Misfire 2000 W
    By justin@justinwa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2008, 01:33 AM
