Thread: The dreaded pinch bolt replacement (stainless?)
Results 1 to 10 of 13
  1. The dreaded pinch bolt replacement (stainless?)
    May 2012
    Nr Barmouth Gwynedd
    I have read a lot about the dreaded top arm pinch bolt on the American forums and they seem to be using stainless long pinch bolts (bought from regular hardware stores) and lots of preventative corrosion products and claim that they can remove the pinch bolts with no hassle from then on.
    I was wondering if anyone on this forum had tried similiar and what results they achieved? Anyone tried marine grade bolts?
    Im no engineer and so dont understand the forces that this bolt will endure so was going to play it safe and get it from Audi but they seem to be a tad expensive for what is essentially a high tensile bolt.
    Could anyone tell me if these would do the trick? : M10 x 100 mm A4 Stainless Steel Hexagon Head Bolt Hex Bolts Din 931 | eBay
    If not could anyone point me in the right direction of some that will.
    I look forward to your swift responses.
    Thanks.
    2002(52) AUDI ALLROAD QUATTRO 2.5 V6 TDI AUTO TIPTRONIC
    1996(N) 300 series Discovery XS 3.9 V8 efi, manual, single point LPG converted
  2. Re: The dreaded pinch bolt replacement (stainless?)
    May 2012
    Glasgow
    Watching with interest, I had a nightmare with the tre pinch bolts and encased the new ones
    with a big layer of copper slip afterward.
    dread to think what the upper control arm ones are like!
    2001 A6 Avant 1.9tdi 130 manual AWX 203k+++ "Come to kindly terms with your @ss for it bears you." - John Muir.
  3. Re: The dreaded pinch bolt replacement (stainless?)
    Aug 2011
    Meath
    I assume they're for the top suspension links? I find that every bolt bends a little I also think most of them are over tightened. When I replace them I tap them through from the inner wing side and put the nut on the outside. If and when it needs to come out again you can easily drive it out with a drift. These bolts are single use.
  4. Re: The dreaded pinch bolt replacement (stainless?)
    Pembrokeshire
    22 Post(s)
    stainless to replace a high tensile bolt ???
    stainless is fine for some applications but not where a lot of force and stress is involved.
    buy new bolts from a dealer or febi etc..., ones actually designed for the job, clean out the holes they go in, fit the new bolts with some copper grease then once a year take 5 mins to remove the bolt , clean it and re fit with grease again. this is a guaranteed way to make them easy to remove in the future, and doesn't involve using a material thats not designed for the job.
  5. Re: The dreaded pinch bolt replacement (stainless?)
    May 2012
    Nr Barmouth Gwynedd
    I did wonder hence asking before doing, Ive got some proper (febi) ones from an indy mechanic who I am friendly with but just wondered if anyone had any good preventative measures to sort Audis mistake out, I always prefer to use new nuts and bolts even when it says you can re use.
    I was considering making it part of my 6 month/yearly service shedule as it appears to be an important bolt to unfasten to do a few of the front end repairs, would you recomend, removing it completely, re greasing/anti corrosion agent and then also covering the external knuckle with grease? Should you use a new bolt every time/after a certain time period eg: 5 years? (cheap and easy enough)
  6. Re: The dreaded pinch bolt replacement (stainless?)
    May 2012
    Glasgow
    Some interesting stuff here in case the going gets tough removing the old ones:
    PINCH BOLT REMOVAL made easy - pics
  7. Re: The dreaded pinch bolt replacement (stainless?)
    Sep 2007
    Windy Westcountry!
    That's a good guide. Cheers for posting. Mine must be due for taking out and replacing with some new heavily greased bolts as well. They've been in there since 2004.
    Good luck and let us know how you get on.
  8. Re: The dreaded pinch bolt replacement (stainless?)
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    +1
    Without knowing what steel grade the oem part is ,it's difficult to know if A2/A4 grade stainless is strong enough. Stainless parts will probably be not as strong as the original high tensile oem part and also the thread pitch might be difficult to replicate as it will be metric fine pitch series. If the OEM part is given a good coating of copper anti sieze ,the pinch bolt should outlast the life of the car . How many times do you remove a pinch bolt ? It's good practice to renew these in this kind of critical application rather than use the old ones. If you can clean up the holes with a 10mm dia. reamer before appyling the anti sieze so much the better.
    I certainly would not gamble on my life or those of my passengers in this guessing game on bolt strengths.
    Skoda Octavia II SE 1.9PD TDI
  9. Re: The dreaded pinch bolt replacement (stainless?)
    Sep 2011
    Almeria, Spain
    How difficult would it be to find out the OEM bolt/thread specs, would aforementioned Febi be able to supply that or would we need to go to Audi and would they even then supply the specs?
    Jon
  10. Re: The dreaded pinch bolt replacement (stainless?)
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Quote Originally Posted by bootie3367 View Post
    Jon
    I doubt if VW would even respond to a private individual but you may get a response from FEBI.
  1. Front strut pinch bolt (tips)
    By spartacus 68 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-09-2011, 08:51 AM
  2. Pinch bolt/spring removal
    By toadus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-04-2011, 04:30 PM
  3. pinch bolt
    By ju1es1970 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2010, 09:03 AM
  4. cv boot replacement, top pinch bolt
    By chrismac10 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-03-2009, 10:41 PM
  5. Help !! Can't get pinch bolt out of clamp
    By SteveRW in forum Passat - Archive Topics
    Last Post: 03-03-2007, 06:52 PM
