Thread: "01273" fault code, part code descriptions.
Results 1 to 10 of 10
  1. "01273" fault code, part code descriptions.
    Jan 2013
    Basingstoke
    I have an intermittent blower failure issue with my A6 that is producing the above fault code. Within the fault it lists (V2) which I take it must be the complete blower fan unit.
    Can anyone tell me what these other actual parts are that are also listed?
    Control Module for air blower (J126)
    Climatic control module (J255). Are these modules that are part of, or one of them the whole front control console where the blower buttons & fan/climate control buttons are located?
    If not, where would these parts be located & any ideas of cost at all? I've been told that I may need to replace the whole control unit which houses all of the control buttons at around £700!! But if the VCD is listing both J255 & J126 as possible fault areas (as well as other poossibilities), then I'm hoping that I wont have to buy the whole unit.
    Any ideas please guys?
    Many thanks,
    Jaset
  2. Re: "01273" fault code, part code descriptions.
    130 Post(s)
    1972 Post(s)
    Presumably you are referring this this code listing?
    01273 - Fresh Air Blower (V2)
    Possible Causes
    • Fresh Air Blower (V2) defective
    • Control Module for Fresh Air Blower (J126) defective
    • Short of open circuit in wiring to Fresh Air Blower (V2)
    • Climatronic Control Module (J255) malfunctioning
    Possible Solutions
    • Check Fresh Air Blower (V2)
      • Perform Output Test (Check Air Vents while Blower is active)
      • Check Meas. Blocks while Blower is active
    • Check Control Module for Fresh Air Blower (J126)
    • Check wiring and connectors
    I find this is usually down to worn brushes on the fan motor.
  3. Re: "01273" fault code, part code descriptions.
    Southern County Softy
    20 Post(s)
    Steve,just to add to this.
    The car was scanned and the fault was logged and cleared.
    After turning the ignition off and back on, the fan stopped blowing.
    We removed the plenum chamber cover to get a look st the motor to check connections.
    After a gentle tap on the top of the blower it started.
    Would motor brushes fail in just over 3 years and can the be replaced.
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  4. Re: "01273" fault code, part code descriptions.
    130 Post(s)
    1972 Post(s)
    Tapping the motor and it starting is classic brush wear. I find that they will start up if you slap the base of the heater box behind the glovebox.
  5. Re: "01273" fault code, part code descriptions.
    Jan 2013
    Basingstoke
    Thanks Guys,
    I'll get my mechanic to check for worn brushes. The blower unit is under the bonnet as George said but seems a bit bizarre that these would be worn on a 59 plate car?
    The fault hasn't occured again since we looked at it (dont speak too soon), but I'll take the cover off I think, so I can tap it if & when it occurs next just to eliminate coincidence.
    Cheers,
  6. Re: "01273" fault code, part code descriptions.
    130 Post(s)
    1972 Post(s)
    I wish you had said at the beginning this was a 4F A6, I am not a bloody clairvoyant!
  7. Re: "01273" fault code, part code descriptions.
    Jan 2013
    Basingstoke
    Perhaps they should call you Mistic Meg? Sorry mate its my 1st Audi. I appreciate your time in trying to help thiough, it really is appreciated!
  8. Re: "01273" fault code, part code descriptions.
    130 Post(s)
    1972 Post(s)
    Quote Originally Posted by Jaset View Post
    I've been called far worse on a regular basis...
  9. Re: "01273" fault code, part code descriptions.
    Jan 2013
    Basingstoke
    Thanks again mate,
    I'll keep you & George updated on the blower situation, but its a great car apart from that! :O)
  10. Re: "01273" fault code, part code descriptions.
    Nov 2010
    Middle of nowhere
    Thanks again mate,
    Jaset,
    How did you resolve this problem in the end ? I have the same issue and fault code in VCDS
  1. Fault code 17978 "Engine blocked my immobiliser. HELP!
    By Mr Tibbs in forum VCDS - Users Locations
    Last Post: 22-09-2015, 10:45 AM
  2. TDI glowplug "Open Circuit" fault code
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2010, 09:14 AM
  3. Fault Code help for the "new boy"
    By Rick M in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-06-2009, 08:39 PM
  4. Please Help Fault code "Emmissions Workshop!
    By AndyJug in forum Chat - Anything with wheels
    Last Post: 08-10-2008, 04:36 PM
  5. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
