Thread: 1.9tdi thermostat replacement
Results 1 to 10 of 16
  1. 1.9tdi thermostat replacement
    Mar 2007
    nr Gloucester
    Since I've had my car the temp gauge has never got above 70 deg. I changed the CTS hoping that was the problem but to no avail. Pretty sure its the thermostat after reading this...
    Thermostat, water pump or sender unit
    I'm gonna have a go myself, just wanted to confirm location of thermostat on a 1.9tdi 130? I presume its take the radiator hose off to drain? Also how much coolant should i expect to replace and at what ratio.. 50%?
    I normally use genuine parts no matter what but would a cheapy ebay one do the trick? trying to save money as skint at the mo.
    Thanks in advance
    Ad
    Audi A6 (C7) 3.0 BiTDi Black Edition 2016
  2. Re: 1.9tdi thermostat replacement
    Aug 2011
    Meath
    Thermostat isn't expensive mate. There's a drainage tap at the bottom of the radiator you can drain a lot of the coolant there and most of the remainder at the oil cooler. There's 2 hex bolts holds the thermostat cover in place take them out, you can leave the hose on if you wish and move the cover away from the engine. Take out the old thermostat (note which way it goes) and put in the new one and the new seal, don't over tighten the bolts. Make sure all pipes are on properly and the drainage tap is closed then add coolant (G12) don't dilute it. Coolant should be changed every few years anyway. Take you less than an hour
  3. Re: 1.9tdi thermostat replacement
    7 Post(s)
    Just to add, the thermostat is locked into the plastic flange section.
    To remove it twist then gently pull. It is easy to break the plastic retaining tabs in the flange housing.
    The flange is tucked up behind the alternator and the two bolts are either 5mm allen (hex) or 10mm normal bolts heads so either should fit. You do not need to remove the alternator.
    2 0 0
  4. Re: 1.9tdi thermostat replacement
    Mar 2007
    nr Gloucester
    Thanks guys, much appreciated. Does genuine or not make much difference?
  5. Re: 1.9tdi thermostat replacement
    Aug 2011
    Aldershot
    6 Post(s)
    Sorry to high jack the thread, I'm also experiencing the temperature gauge not going above 70 degrees on a 1.9tdi, I've had the car 8 years and I'm sure it used to go to 90 degrees on most good runs, but now I only see 70 degrees, I'd put it down to the cold outside temperature and having the heating on 26 degrees, but seeing this post, it's now got me thinking, could the engine not running at it's normal 90 degrees, also reduce fuel economy? I'm struggling to return the MPG I used to get?
    Paul
  6. Re: 1.9tdi thermostat replacement
    Aug 2011
    Meath
    Yes if the ecu thinks the car is at a lower temperature it will use a different map with different settings and parameters so it will effect fuel economy
  7. Re: 1.9tdi thermostat replacement
    Mar 2007
    nr Gloucester
    Quote Originally Posted by pdlh View Post
    Paul
    Fuel economy will be downs the car is constantly over fuelling to get up to temperature. it should get up to 90 and sit there in all but extreme cold temperatures
  8. Re: 1.9tdi thermostat replacement
    7 Post(s)
    It is good practice, whilst the system is drained down to replace BOTH the temp sender and the thermostat, as they BOTH fail.
    Saves you buying antifreeze twice.
  9. Re: 1.9tdi thermostat replacement
    Guys, is there a 'diagnostic procedure' for determining whether its the temp sender or thermostat (or both) that's failed? E.g. Using VCDS?
  10. Re: 1.9tdi thermostat replacement
    Aug 2011
    Meath
    VCDS scan will tell you if the CTS has a fault
  1. Question Thermostat replacement
    By cadoc in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-03-2010, 10:09 PM
  2. Thermostat replacement
    By pg20 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2009, 07:38 PM
  3. 2.8 v6 thermostat replacement
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-08-2009, 08:05 PM
  4. Thermostat replacement
    By Jimstobb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2007, 02:05 PM
  5. 1.9TDi Thermostat
    By Hywel in forum Chat - Completely Off Topic
    Last Post: 19-09-2006, 12:27 PM
