Thread: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
Results 1 to 10 of 18
  1. Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    Jan 2010
    Colchester, Essex. UK
    Hi, Im at the end of my tether, if any one can help I would appreciate it.
    Got a 2006 (pre dpf) Golf 2.0 GT TDi 170 DSG with BMN engine code, that has a cold starting issue. It does always start eventually, and once it has started, it will start first time every time for the rest of the day. Only when the car has been left overnight will it do it again. It turns over several times, and then eventually fires and stutters into life, stuttering for the first 5 seconds or so. Originally we had a glowplug code coming up. This has been going on for a year now, and I just want it sorted.
    To date, we have done the following work
    - 4 new glow plugs
    - new starter motor
    - new injector seals
    - new in tank fuel pump
    - new high pressure fuel pump
    - new fuel filter
    - new battery
    - fuel additive
    Originally we thought it was fuel system related, so we changed the starter motor and battery as these often cause a problem on mk5's.
    Once the glowplugs were changed, the problem went away for 2-3 days, then started doing it again, EML came on, read codes - glowplug no.1. Changed glowplug, all was fine, then it came back again.
    It appears to be glowplug related, but I dont know how to fix
    Please help!
    Thanks in advance.
  2. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    Aug 2011
    Meath
    You replaced a lot of parts without a VCDS scan! it sounds like a coolant temperature sensor, scan with VCDS! http://www.ross-tech.com/vag-com/dtc-comparison.html
  3. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    131 Post(s)
    1973 Post(s)
    Injector seals? Has the car not had the injector recall carried out? Is the engine losing coolant?
  4. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    Jan 2010
    sorry, I forgot about the Coolant Temp sensor - thats another item that was changed - for a genuine one
    I have scanned it with VCDS, I havent got the code to hand, but it is glowplug no.1.
    The car has had 4 new injectors by Volkswagen.
  5. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    Jan 2010
    No, it's glow plug number 2.
    Address 01: Engine Labels: 03G-906-018-BMN.clb
    Part No SW: 03G 906 018 DF HW: 03G 906 018 DF
    Component: R4 2.0l PPD1.2 4345
    Revision: --H32--- Serial number: VWZ7Z0F8152224
    Coding: 0000078
    Shop #: WSC 00187 210 89766
    VCID: 6CDCB3AE4F287C78ED4
    1 Fault Found:
    001650 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 - 006 - Electrical Fault - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 173860 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 07:23:05
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 10.06 V
    Bin. Bits: 01110000
    Temperature: 15.0°C
    I have changed the glow plugs twice in the space of year now, Both times Ive used Beru ones from Euro's which I now hear are not up to the job by looking through the forums. What I cant seem to understand is why number 2 keeps failing. Could it be the wiring or a relay, or something else? Definately the starting fault only happens when the outside temperature falls under 5-6 degrees, so Im pretty sure it must be down the the glowplugs, as I am of the understanding that glowplugs on these cars are only required when the temperature is under 7 degrees.
    I'm going to fit 4 new genuine VW glowplugs (unless anyone can recommend even better ones), but I need to check if theres anything else that needs checking at the same time.
    Sorry Crasher I didnt answer your question, - I changed the injector seals as a VW 'Specialist' claimed that it was the fault - which it wasnt, this was nearly a year ago and was one of the 1st things I did. Also, the car doesnt use a drop of coolant, so no pourous head, head gasket problems, etc etc.
  6. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    UK Ex-pat now in Australia
    There is a technical solution for VW dealers regarding the glowplug control module so it may be worth letting a VW dealer look at that.
    Had MKV GTI, Now Ford Falcon
  7. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    131 Post(s)
    1973 Post(s)
    One glow plug will not cause a problem.
  8. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    nottinghamshire
    what about wiring to the glow plugs
  9. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    Mar 2013
    Swaffham, England
    Quote Originally Posted by FLENG2008 View Post
    I'd also look at the wiring, it's probably the part of the loom that comes away from under the battery. I had this on my Mk1 Leon Cupra TDI. Once it was changed the problem was cured.
  10. Re: Golf GT TDi 170 BMN - Cold Starting Problem - Changed everything !!!
    131 Post(s)
    1973 Post(s)
    No it is part of the injector harness on the 2 litre 16v, nothing like your MK1 Leon.
    Glow plug
    Harness
  1. TDI 170 poor cold starting
    By ace977 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-12-2012, 11:46 AM
  2. golf 170 bmn into passat bmr?
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2010, 12:55 PM
  3. Question Cold Starting Problem MK4 Golf.
    By jrwilshire2003 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2008, 09:36 AM
  4. Cold Starting Problem Golf 1.9d (95)
    By ak07oct in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-02-2007, 03:45 PM
  5. Cold Starting Problem Golf 1.9d (95)
    By ak07oct in forum Chat - Completely Off Topic
    Last Post: 21-12-2006, 08:41 PM
