Thread: 3.0tdi actuator issue
Results 1 to 10 of 18
  1. 3.0tdi actuator issue
    Jan 2013
    Bolton
    Hi everyone this is my first post on here
    the emission control light popped up today on my car it's on 136k and spends all it's life on the motorway. I know one glow plug needs replacing but when I took the engine cover off the actuator for what I presume is the inlet manifold is constantly opening and closing I've done a vid to show this
    Audi a6 3.0tdi actuator issue - YouTube
    after a short drive the car doesn't seem to have lost any power and so far hasn't gone into limp mode. I'll be getting the car hooked upto a fault code reader tomorrow but I was wondering if anyone had seen this before?
  2. Re: 3.0tdi actuator issue
    Sep 2011
    Lurking over a keyboard ...
    The answer you seek is here... Link:- Help with 2.7TDI engine "pulsing"
  3. Re: 3.0tdi actuator issue
    Jan 2013
    Bolton
    You sir are a star! thank you for that
  4. Re: 3.0tdi actuator issue
    Sep 2011
    No worries... if it wasn't for this forum my car would have made me bankrupt
    I got mine from here... Link:- BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! ) - Page 7
    Genuine Siemens VDO part.... in video the blank bits have Audi P/N under them...
    Here is video of the old throttle with plastic gear eaten... Link:- BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! ) - Page 5
    Depending on your VIN it could have the 4 Pin or 5 Pin electrical connection throttle...
    You can access VDO online catalogue here link:- VDO Replacement Parts Online Catalog
    I recently saw a new one on ebay go for a £100 or so! get googleing with part numbers fellow V6 owner! ...
  5. Re: 3.0tdi actuator issue
    Jan 2013
    Bolton
    That's a great help, its a relief to see its nothing major. I take it I can still drive the car for a couple of days with the fault with out causing any major issues
  6. Re: 3.0tdi actuator issue
    Sep 2011
    I really can't answer that question...
    I'm just a geeky owner who likes to solve his own problems and help others ... not a mechanic...
    You could PM the people who have had this fault...
    Gavin0478
    Ming
    Milu-
    There are some proper mechanic posters like Crasher, A8 Tech, Peter D, Adamss24, Zollaf... (sorry if a forgotten others )...
    There are many and maybe they will come along and post...
    I caught mine at the milder stage... I was not yet getting the EGR cooling flap and Turbo VNT actuator moving...
    1 1 0
  7. Re: 3.0tdi actuator issue
    Oct 2012
    United Kingdom
    12 Post(s)
    I had that same issue and a new throttle butterfly was needed.
    Easy part to fit.
    Part number V059 145 950 R C6C2 Valve at around £300 plus vat from dealer for my asb engined a6.
  8. Re: 3.0tdi actuator issue
    Jan 2013
    Bolton
    Hi I've had the car looked at today the fault codes are as follows
    04203 throttle valve stuck or difficult to move p1068 upper limit reached intermittent
    05504 throttle actuator bank (bank 1) malfunction p1580 not a plausible signal
    ive been quoted £220 including vat fitted with the part coded in so it's getting done Monday
    thanks for all the help I appreciate it
  9. Re: 3.0tdi actuator issue
    Oct 2012
    United Kingdom
    12 Post(s)
    Thats a very good price. i went genuine with the throttle butterfly because there has been many revisions as nost have a combination of metal and plastic cogs which wear.
  10. Re: 3.0tdi actuator issue
    Jan 2013
    Bolton
    The way I'm looking at it is that's its lasted 5 years and 136k miles so If the part lasts that long again i can cope with that. I only ever drive the car on motorway or long drives so I can't see it being an issue as more than likely its soot build up that causes them to wear in the first place. Time will tell though
  1. Question Clutch issue - 04 2.0TDi
    By BradHatton in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-11-2012, 04:56 PM
  2. 3.0tdi issue
    By Snatchrat in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-11-2012, 05:18 PM
  3. B7 2.0Tdi 170 aircon issue
    By deeempee in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-10-2011, 07:06 PM
  4. Throttle valve/actuator issue
    By staffop1 in forum VCDS - Help Requests
    Last Post: 01-12-2010, 11:57 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
