Thread: vw passat b6 16'wheel to 18'wheels change
  1. vw passat b6 16'wheel to 18'wheels change
    Hi,i have just bought some ronal style alloys,they are 112pcd and offset of 35,my current wheels are vw cataluyna 112 pcd and 45 offset,16 inch alloys change to 18 inch alloys,will they fit okay,do i need spacers or something,225/50/16 - 225/50/18, thanks in advance.
  2. Re: vw passat b6 16'wheel to 18'wheels change
    46 Post(s)
    Your speedo will read 5mph more with those 18" tyres .. you need 225/40/18
    Looking online the B6 passat has a ET of 45.
  3. Re: vw passat b6 16'wheel to 18'wheels change
    Thanks for reply,can i still use these wheels for this car,i have also read online that the ride might be a bit hard with 225/40/18,could i use 225/45/18 instead,thanks.
  4. Re: vw passat b6 16'wheel to 18'wheels change
    46 Post(s)
    no you need 225/40/18 for your speedo to be correct
    there will be very little difference from a 45 to a 40 tyre plus anyway the 18" will be hard compared to the 16" so you'd be best sticking with the correct tyre size as it could invalidate your insurance
    not sure on the et problem but im sure if you do a search the answer will be out there
  5. Re: vw passat b6 16'wheel to 18'wheels change
    Thanks for your help,happy new year.
  6. vw passat b6 16'wheel to 18'wheels change
    Jun 2012
    Nottingham
    ET should be fine, they'll just sit 10 mm further out in the arches. Chances are the 18"s are the same width as the 16"s (bearing in mind you've quoted 225 for both) so apart from the fact that you may get a small amount of inner edge tyre wear, there shouldn't be a problem.
  1. Please Help Passat engine change
    By abbottgaz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-07-2008, 08:25 PM
  2. Passat wing change
    By SMEG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-07-2008, 10:46 PM
  3. pad change on a passat
    By jeepster1961 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-05-2008, 09:24 AM
  4. cambelt change on a 2.0 passat
    By sompop in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 01:25 PM
  5. Passat Cambelt change
    By excaliber in forum Passat - Archive Topics
    Last Post: 21-03-2007, 10:43 AM
