Thread: Golf gt tdi 150 has started to make a whistling sound when accelerating
  1. Golf gt tdi 150 has started to make a whistling sound when accelerating
    Dec 2008
    hi my golf gt tdi 150 has started to make a whistling sound when accelerating. I know the normal turbo whistle type sound which is normal but this sound has only started to happen, every time you accelerate it makes a whistle type sound, same type sound as when you let air out of a tire but louder. seems to come from passenger side of car, when driving if you open the drivers window you hear normal turbo spool sound but when you open passenger window you can here the leaking air type sound
    car drives normal, no black smoke or loss of power, hoping it just a loose pipe, any suggestions please
    thanks
  2. Re: Golf gt tdi 150 has started to make a whistling sound when accelerating
    Southampton, UK.
    I'd be hoping it'd be that too. Best check the obvious first, like split hoses and connections.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: Golf gt tdi 150 has started to make a whistling sound when accelerating
    Oct 2012
    Dunoon
    Had this before as-well, turned out to be a split hose, best option check for splits and loose hoses
  4. Re: Golf gt tdi 150 has started to make a whistling sound when accelerating
    Jul 2007
    glasgow
    35 Post(s)
    could be a gasket as well , look for soot
  5. Re: Golf gt tdi 150 has started to make a whistling sound when accelerating
    130 Post(s)
    1972 Post(s)
    The usual leak point on the ARL engine is the fitting for the 90 degree bend hose out of the bottom of the intercooler, the aluminium retaining barbs wear against the steel retaining clip as each boost increase/decrease causes the fitting to move back and forth. Usually a new hose is required and soon it may blow off completely and cause major smoking and loss of power.
  6. Re: Golf gt tdi 150 has started to make a whistling sound when accelerating
    Feb 2018
    North Yorkshire
    Mines doing the same thing I have a pd130 gt tdi and somebody mentioned a bearing in the turbo might be on its way out is this true, or could it just be a pipe, can anyone help
  7. Re: Golf gt tdi 150 has started to make a whistling sound when accelerating
    130 Post(s)
    1972 Post(s)
    Could you start your own new thread please, this one is six years old.
  1. Loud Whistling while accelerating
    By mrgdh in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-06-2010, 06:56 PM
  2. Whistling noise when accelerating
    By southbank in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2009, 03:38 PM
  3. GT TDI 150 Turbo whistling at 1500 - 2000 RPM
    By Buzzlightyear_2 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-07-2008, 02:22 PM
  4. GOLF MK 4 Brakes Make 'Click' Sound
    By jay_nation in forum Golf MK4 - 1999 - 2004
    Last Post: 18-01-2008, 03:05 PM
  5. whistling sound
    By apple mike in forum Golf MK2 - 1984 - 1992
    Last Post: 02-11-2007, 08:44 PM
