Thread: Audi A4 B6 NO Power to drivers door. HELP !
Results 1 to 10 of 11
  1. Exclamation Audi A4 B6 NO Power to drivers door. HELP !
    Sep 2010
    Birmingham
    a4 b6 avant NO POWER TO DRIVERS DOOR ?!? HELP !!
    Hi all im new to the site and new to audis just wondered if anyone can help ?
    Im having trouble with my a4 b6 drivers door there seems to be no power or little power to the door ? windows either side dont work and drivers door wont lock with remote ? no electric window lights or electic mirrors also not showing door is open on panel on clocks ? any info would be great !!
    heres what i have already tried : wiring from door to car under rubber checked and there was a few wires broken ( brown and green ones ) so ive had them soldered and thought this would cure the problem but hasnt ? it has brought the power back to the floodlight in the door and the alarm led on top of the door card flashes now but also doesnt go off when driving ? but still no power to anything else !
    - Checked all fuses and all ok ?
    loosing the will to live !!!! PLEASE HELP !
    thanks louie
  2. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Sep 2008
    chester
    17 Post(s)
    You said you checked the wires,but did you check through the hinge rubber gaiter right through to the inside,doing a continuity test,the wires break inside,not obvious from the outside,also check under the carpet passenger side carpet for damp.
  3. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Jul 2009
    warrington england
    I had the same problem i ended up replacing the loom about £100 from audi. someone had tried to repair it before.
  4. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Sep 2010
    Birmingham
    Quote Originally Posted by nevo View Post
    Hi thanks for the reply I pulled the rubber gaiter right back to where the shrink wrap is and found some broken wires and soldered them it brought back power to floodlight in door and led alarm on top of door ? Is that the comfort module under passenger seat ? Thanks
  5. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Sep 2010
    Birmingham
    Quote Originally Posted by dan2134 View Post
    Hi dan thanks for the info did you have any power at all ? Ie. speaker , floodlight , led alarm ? Just wondering whether it could be some else ? Very annoying not having any windows ! Thanks Louie
  6. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Jan 2011
    derby UK
    Did you try pulling the door plug out. Mine had rotten pins in connector itself.
  7. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Sep 2010
    Birmingham
    Quote Originally Posted by Google44 View Post
    Hi tha is for the reply yes I unplugged connector but all looked good ?
  8. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Jul 2009
    warrington england
    I had power to some of the door at first then it all failed there were only about two wires that had not broke. i checked the whole system and it was the door loom as the wires flexed as the door opened and closed they made and broke contact. A new door loom was the only fix. the door connector was fine.
  9. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Sep 2008
    6 Post(s)
    Strip out the door card to investigate properly. Does make you wonder how the wires were broken in the first place? There's a hidden screw behind the plastic trim in the door handle. A multimeter is invaluable to check continuity signal.
    2016 BMW i3 REx (80k)
  10. Re: Audi A4 B6 NO Power to drivers door ? HELP !
    Sep 2010
    Birmingham
    Thanks for everyone's help problem solved the issue was the loom it had 2 split wires further into loom so before you buy any parts do a continuity test on loom ! Thanks again !
  1. Audi A6 C5 Drivers Door Will not open _ 2000_1.9tdi
    By KGB83 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-08-2012, 07:31 PM
  2. Audi A6-C6 drivers door trim removal help please
    By Audime in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-11-2011, 06:45 PM
  3. rubber gromitt and power to my drivers door
    By c4sper7 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2011, 05:29 PM
  4. Wanted ! Manual window regulator for 3 door drivers door!
    By m0mjt in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2010, 10:56 AM
  5. Please Help Drivers door has no Power and wont lock
    By Danbalme in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2010, 05:37 PM
