Thread: Beep on Locking - Passat B6
Results 1 to 10 of 10
  1. Beep on Locking - Passat B6
    Dec 2007
    Brighton, UK
    Hi all
    Just had my Passat serviced at my local VW dealer - excellent personal service here in France, plus two years free European breakdown service and courtesy car because it was carried out by a VAG garage. Long Life service 189€.
    I also asked them if they could enable the beep/chirp when locking function for me at the same time. Yes, of course they said. But when I picked up the car there were five technicians standing around the car and the VCDS unit scratching their heads! Seems like it is something they would like to know how to do, but don't get asked very often. They will be investigating this for me.
    In the meantime if anybody has any clues I could pass to the garage to help them with this I would appreciate it.
    Many thanks to all.
  2. Re: Beep on Locking - Passat B6
    Mar 2011
    Clitheroe, England
    11 Post(s)
    So the electrics on an English car (ok German I know, but English registered) has got French mechanics scratching their heads? I bet there's a few British mechanics thinking that this is karma coming back to bite them for all the Pugs, Renaults & Citroens they have to deal with .
    I have enabled the chirp, but can't tell you the process off the top of my head. Someone like A6 Chris or MFGF will be able to though I'm sure. If you don't get any joy, let me know & I'll hook mine up again & jot the steps and modules down for you.
    The Only Way Is A6!
  3. Re: Beep on Locking - Passat B6
    46 Post(s)
    VW Passat (3C) - Ross-Tech Wiki
    [46] - Comfort System
    Adaption - Channel 010
    Type of Confirmation when locking the Car via Remote Control.
    0 = Confirmation OFF
    1 = Confirmation via Blinker/Turn Signal
    2 = Confirmation via Beep/Horn
    3 = Confirmation via Beep/Horn & Blinker/Turn Signal
  4. Re: Beep on Locking - Passat B6
    Norfolk
  5. Re: Beep on Locking - Passat B6
    Mar 2011
    Clitheroe, England
    11 Post(s)
    See? Right on cue. I'm off to choose tonight's lotto numbers lol.
    The Only Way Is A6!
  6. Re: Beep on Locking - Passat B6
    Dec 2007
    Brighton, UK
    Thanks for the information guys. So I have two lots of stuff to show the techies....
    10 94 Bit
    7 1 Adaptation of Horn Confirmation locked
    6 0 not relevant/unused
    5 0 Unlocking Confirmation (Horn) via Kessy
    4 1 Unlocking Confirmation (Blink) via Kessy
    3 0 Unlocking Confirmation (Horn) via Remote Control
    2 1 Unlocking Confirmation (Blink) via Remote Control
    1 0 Unlocking Confirmation (Horn) via Door Locks
    0 0 Unlocking Confirmation (Blink) via Door Locks
    11 15 Bit
    7 0 not relevant/unused
    5 0 Locking Confirmation (Horn) via Kessy
    4 1 Locking Confirmation (Blink) via Kessy
    3 0 Locking Confirmation (Horn) via Remote Control
    2 1 Locking Confirmation (Blink) via Remote Control
    1 0 Locking Confirmation (Horn) via Door Locks
    0 1 Locking Confirmation (Blink) via Door Locks
    ...and
    Coding
    Bearing in mind that they will be using the official VW software and I will have to convey the message to them in my pigeon French, which numbers will mean the most to them?
    Your help is appreciated.
    PS: I expect the French techies will be posting on their own VW site soon!!
    PPS: Tried to remove the white space in this posting ,but failed
    Last edited by Frelon; 28-11-2012 at 10:43 PM. Reason: Tried to remove white space!
  7. Re: Beep on Locking - Passat B6
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    The explanation to the French techies will be the most difficult thing in this process.
    Credit to Martin's excellent site which taught me the long coding schematics a couple of months ago which I was able to apply when using VCDS on my own car.
    Simple version: All they need to do is change the Bit 7 of Byte 10 of the long code on your convenience module to uncheck the "Adaptation of Horn Blocked" option. The ATA Confirm option then appears as an MFD menu option on your dash display allowing you to switch the chirps on / off without needing to select further adaptation options or change any other parts of the long code. The whole thing (including activating chirps + blink lights for remote, keys and KESSY) can be done by changing the values in Bits 0 through to 5 of Bytes 10 and 11 of the long code but releasing the menu option is the easiest way using the VAS505x diagnostic dealer tools I have been told (if not the case then they can change the other bits as necessary all at once).
    Heres mine (example only as specific to my vehicle) under my 46 Cent Conv module:
    01910A0001860E763004951570085FCE107800 Adaptation of Horn Blocked (Original code)
    01910A0001860E763004151570085FCE107800 Adaptation of Horn Unblocked (New code)
    If using VCDS this change allows options 2 and 3 of the available options as described by A6_Chris under the Adaptation option of the Central Conv Module (aka the Comfort Module) should VCDS users find them unsaveable (Bit 7 is the reason).
    Byte 0 is the first 2 characters, Byte 1 the next 2 and so on. From the above you can see Byte 10 change from 95 to 15 to allow the ATA (Anti Theft Alarm) confirm option.
    Good Luck!
    Mad Mitch
  8. Re: Beep on Locking - Passat B6
    Dec 2007
    Brighton, UK
    Hey, thanks to everybody for the input. As Mad Mitch says the difficulty is explaining this to the French techies! But, they should have some idea how to use VCDS, so just need the final pointers.
    I will let you know how I get on.
  9. Re: Beep on Locking - Passat B6
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by Frelon View Post
    I'll be interested in case I need to explain it to my French 'techies'! Have you asked them about changing the injectors....?
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: Beep on Locking - Passat B6
    Sep 2010
    albania
    To have this feature is OEM Anti theft alarm needed ?
  1. auto locking & beep on lock!!
    By burkey1 in forum VCDS - Help Requests
    Last Post: 19-08-2010, 09:13 PM
  2. Activating the beep when locking
    By Chrisman in forum VCDS - Help Requests
    Last Post: 08-08-2010, 04:13 PM
  3. Question locking confirmation beep
    By revver in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-07-2009, 06:12 PM
  4. beep beep beep at certain speeds - help 2007 a6
    By dufus in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-03-2009, 11:58 AM
  5. 1997 A4 - Alarm beep on locking
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2007, 09:17 PM
