Thread: VW Tool + Vag +K Can Commander 1.4
  1. VW Tool + Vag +K Can Commander 1.4
    Nov 2012
    United Kingdom
    Hi, can someone help me I have a VW T5 Transporter 1.9tdi 2007.
    I am planning to fit cruise control - so I bough a cheap cable off ebay <removed>
    So i can change the adaptations and read the odd fault code when needed - I can't really justify buying the VCDS / ross tech for the few times I will need it (It would be sat in the garage most of the time)
    I have installed the software and connected the laptop to the van - its really odd, because it will talk to some control units but not all!!!
    ie. it will talk to the instrument cluster, parking sensors and airbag control units (and even perform tests) and a few others, but it won't talk to the Engine ecu - which is the one i need to talk to to activate cruise control.
    I have used both programs that came with it - <removed> nether will talk to the engine ECU - all I get is a message saying "changing to Baud rate 0" and then unable to connect.
    Anyone any ideas - or is there some other software i can use with this cable?
    Last edited by Guest 2; 13-11-2012 at 10:14 AM. Reason: sorry we cant have clones being advertised on the site
  2. Re: VW Tool + Vag +K Can Commander 1.4
    Norfolk
    That's not a diagnostic cable and why you expected cheap Chines cr*p to work is beyond me. Waste of money.
  3. Re: VW Tool + Vag +K Can Commander 1.4
    46 Post(s)
    Where are you located OP - we may be able to find someone close to you with vcds.
  4. Re: VW Tool + Vag +K Can Commander 1.4
    Aug 2011
    Meath
    Is this an ad?
  5. Re: VW Tool + Vag +K Can Commander 1.4
    46 Post(s)
    Quote Originally Posted by Doctle Odd View Post
    Is this an ad?
    registered email address and ip address checks out so i think not
  6. Re: VW Tool + Vag +K Can Commander 1.4
    Aug 2011
    Meath
    Ok it was just the name of the member that stood out, the real thing costs 10 grand!
  1. Please Help Vag commander
    By phil miller in forum Chat - Completely Off Topic
    Last Post: 06-02-2011, 08:30 AM
  2. VAG K+CAN Commander for 2005 B6
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-06-2010, 08:02 AM
  3. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
  4. VAG K+ CAN 1.4 commander any good?
    By Toon-soldier in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2009, 11:45 AM
  5. VAG commander
    By elecautocr in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 25-02-2009, 09:41 PM
