Thread: MMI 2G High Bluetooth
Results 1 to 10 of 16
  1. MMI 2G High Bluetooth
    Jul 2009
    Cambridgeshire
    Hi all
    Thanks in advance for you help.
    I have just purchased an Audi A6 2005 with the MMi 2G unit.
    It has a Audi Bluetooth phone already in the center arm rest but I want to use to my iPhone via Bluetooth.
    I can see the Bluetooth settings on the dashboard but don't see how to enable it to be discoverable.
    Ive searched high and low online but come up with nothing.
    My phone searches but doesn't find anything.
    I have the latest 5570 update disc but have not yet run these yet,do i need to?
    Can anyone provide me some pointer please.
    Greatly appreciated
    Dave
  2. MMI 2G High Bluetooth
    46 Post(s)
    Press TEL then SETUP and see if it allows you to search for your phone.
  3. Re: MMI 2G High Bluetooth
    Jul 2009
    Cambridgeshire
    Hi thanks for the fast response.
    It doesnt show that, its shows bluetooth and change phone name.
    Ive un paired the handset in the arm rest.
    there is a sim card slot under the phone handset?
  4. Re: MMI 2G High Bluetooth
    Sep 2011
    Lurking over a keyboard ...
    I think you may have the factory fit "Motorola" handset cradle... from what I've read the bluetooth only link to the "Motorola" handset...
    Link:- A6 MMI and Bluetooth Phone
    Maybe you can post some photos?
    If "Motorola" setup cradle will be to the right in armrest compartment...
  5. Re: MMI 2G High Bluetooth
    Jul 2009
    Cambridgeshire
    Damn I think you are right.
    Seems a shame being the Bluetooth option is there.
    Are there swap out modules to replace the complete Motorola setup with a standard Audi Bluetooth kit that will work with the MMi
  6. Re: MMI 2G High Bluetooth
    Sep 2008
    mostly in the garage
    it could be that you can change the setting in the BT module with VCDS, I have done this on my precious VW Touareg. Just had to change one setting similar to
    0 - handsfree over BT
    1 - handsfree only with mobile in cradle
  7. Re: MMI 2G High Bluetooth
    Jul 2009
    Cambridgeshire
    Quote Originally Posted by c4a5er View Post
    Thats something I will look in to.
    I am trying t run the update to the latest 5570 version.
    Instructions say to hold down return and setup to access the update software option.
    that never happens on mine.
    Is there a different method to access the software update?
    Also is VCDS Vagcom, I have this and the cable from a previous VW passat I owned.
  8. Re: MMI 2G High Bluetooth
    46 Post(s)
    Press RADIO first then do the SETUP + RETURN for a few seconds.
    Might take a few times to get the timing correct.
    vcds is the new name and dependant on the year of your old passat the cable may not work as times have gone on and new technology has been used.
  9. Re: MMI 2G High Bluetooth
    Jul 2009
    Cambridgeshire
    I will go give that a shot now. My vagcom is ages old OBDII from a 97 passat, chances are its not going to work.
  10. Re: MMI 2G High Bluetooth
    46 Post(s)
    definitely not going to work
  1. Replies: 25
    Last Post: 27-09-2012, 06:34 AM
  2. Do I have Bluetooth on MMI High?
    By Mogster52 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-01-2012, 05:12 PM
  3. Need help to code mmi with viseeo bluetooth mmi basic plus
    By Quattros in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-10-2011, 10:46 PM
  4. Bluetooth Car Kits for MMI High Systems
    By Incaripod in forum In Car Entertainment
    Last Post: 22-06-2010, 12:12 PM
  5. MMI basic to MMI high upgrade,components equipement
    By coconut in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-09-2009, 02:23 PM
