Thread: Ibiza whining air con compressor
  1. Ibiza whining air con compressor
    Oct 2006
    Sunny slightly hilly Norfolk
    I've got an 09 Ibiza SE SC 1.4 with climate and the air con compressor is noisy. Not to the extent it is obviously broken but you can hear it whining at idle and when you rev the engine. Once you get above 30mph you can't hear it due to road noise etc but I still think there's a problem with it, a view not shared by the dealer,or indeed Seat, who are aware of noisy compressors but apparently can't do anything about it. I think its a bearing or similar going (thank goodness for warranties) but until it lkets go Seat/Dealer won't do anything. Anyone else ahd a similar problem?
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  2. Re: Ibiza whining air con compressor
    Mar 2007
    Suffolk
    yep-ours has just developed this fault too-did you resolve your issue?
  3. Re: Ibiza whining air con compressor
    Oct 2006
    Yes, it was the expansion valve apparently. I had to take it to another dealer for a second opinion after I got in contact with Seat again and the tech came out and straight away said it was noisy. I don't know how much it cost as it was under warranty. Only problem is the noise is back albiet quieter....
  4. Re: Ibiza whining air con compressor
    Mar 2007
    Suffolk
    Anybody got idea where the expansion valve is for this system and if it can be tested in any way??Local aircon specialist has never heard this sound but suggested a re-gas.Did think could possibly be a vibration in compressor etc which is being made louder through the condenser.On starting there is some faint rattling from behind dash but only when acon is on-then when idle or driving slowly car almost sounds like it has a straight cut gear box as whine builds with engine revs.Again as other post with more speed /road noise etc this is not as audible .When you lift bonnet there is no noticeable noise from compressor or assoc acon pipes although maybe a small vibration on pipe itself although this does not get worse with revs?.
  5. Re: Ibiza whining air con compressor
    Mar 2007
    Suffolk
    OK expansion valve is on os on aircon pipe just in front of susp turret-bolted onto pipe and has electrical connector.
    Priced at around £50 from dealer seems like a bet before compressor.Had a little gas seemed to blow through air vents today though so may be a separate issue?
    cant see how the exp vale would stop whining of aircon when revving engine at low speeds though-anybody any ideas?
    Dealer admitted these do give trouble as well as compressors but the compressor is an even bigger issue on Leon they have told me.
  6. Re: Ibiza whining air con compressor
    Jul 2016
    Sheffield, UK
    Quote Originally Posted by Mike McKinstry View Post
    I know this was over a year ago, but did you ever solve this Mike? I have what sounds like the exact same problem with my Ibiza. If you tried replacing the valve, please do share I'd really appreciate it.
    Thanks in advance =]
  7. Re: Ibiza whining air con compressor
    Oct 2017
    leeds
    when you have your ac systems topped up by professionals they add a certain amount of oil in to the system too there will be a metal plate under the bonnet that tells you how much oil should be added when the systems are re-charged. if you have your ac topped up with the throw away cant you are not replacing the oil in the system if your compressor is making a noise i would recomend you have a full recovery done then a top up with new gas and oil replacement.
  1. Air con compressor
    By Doddy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-12-2010, 04:45 PM
  2. Air-con compressor
    By LivingMudFish in forum Tiguan
    Last Post: 21-10-2009, 06:13 PM
  3. Please Help Air con compressor
    By SMOKINGZULU in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 10-05-2009, 02:34 PM
  4. Important air con compressor
    By mujahidkadri in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2009, 01:53 PM
  5. air con compressor
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 05-09-2008, 08:41 PM
