Thread: portable fault code reader
Results 1 to 9 of 9
  1. portable fault code reader
    Aug 2008
    hi there everyone
    again looking for a little advice. i have a 1999 1.8t sport auto saloon and would like to purchase a fault code reader. could anyone advise me of the best one to purchase without spending a small fortune. i have looked at some Auctel units but i am unsure which will suit my car.
    thanks in advance mark
  2. Re: portable fault code reader
    Aug 2011
    Meath
    I have the old orange version of this, it won't code, adapt or do anything fancy. http://www.ebay.ie/itm/170907206581?...#ht_1171wt_932
    For a few quid extra you could have VCDS lite which would be better for your car
  3. Re: portable fault code reader
    Jul 2010
    Brighton
    I have one of these CAR FAULT CODE READER ENGINE SCANNER DIAGNOSTIC RESET TOOL OBD 2 CAN BUS EOBD | eBay and it works great and very easy to use, it scans for codes tells you what the code means and you can also clear codes with it very handy little tool and saves getting the laptop out just to read a code, I also have VCDS lite and have had very little need to use it so far.
  4. Re: portable fault code reader
    Aug 2011
    Meath
  5. Re: portable fault code reader
    Mar 2009
    West Yorkshire
    i purchased this one
    D900 Universal Any Car OBD2 EOBD Fault Code Reader Scanner Diagnostic Scan Tool | eBay
    and it works great, also does the Live data scan as well, it has a lot of manufacturers as well, it didnt show a vauxhall(my brother has an astra) and he had a few error, i just selected OTHER in the manufacturer and cleared his codes......BUT it does not do the air bag etc.
    kevin
  6. Re: portable fault code reader
    Quote Originally Posted by unclespevie View Post
    kevin
    It does not say it works with VAG cars, have you used it on a Passat?
  7. Re: portable fault code reader
    Aug 2011
    Meath
  8. Re: portable fault code reader
    Mar 2009
    West Yorkshire
    Quote Originally Posted by caldirun View Post
    mine is a B5 1.9tdi 130 highline and reads it perfect....2004 passat
    it also has many other makes to select, but as i say it works on mine fine and my brothers astra(under OTHERS for make) and even checked out my daughters mini, was ok no faults....
    i bought this cable
    OBD2 Scan VAG COM USB KKL 409.1 Free Software VW AUDI Code Reader Dignostic Tool | eBay
    and downloaded the vcds lite software and works a treat on my car with a laptop....doas what i need to do, and for that price, well cant argue....
    kevin
  9. Re: portable fault code reader
    Nov 2006
    I've got a 2002 1.8T. I bought this unit last year. Works spot on. I've read several codes with mine and it clears them as long as the problem has been rectified. Try the link;
    VAG 405 Replacement, the Vgate VS450 VW Group Diagnostic OBD Tool. The VAG405 is now obsolete and no longer in production: Amazon.co.uk: Car & Motorbike
  1. Fault Code Reader
    By Yowfailed in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-03-2012, 07:14 AM
  2. How much and were can i get a fault code reader for my a4
    By Damrob in forum VCDS - General Questions
    Last Post: 14-11-2011, 09:54 AM
  3. Fault code reader
    By 6182marcs in forum Golf MK4 - 1999 - 2004
    Last Post: 04-02-2010, 10:55 AM
  4. fault code reader
    By CHARYBDIS in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-07-2009, 11:13 PM
  5. Fault code reader.
    By frank-59 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-07-2008, 09:28 AM
