Thread: The dreaded wiper issue
Results 1 to 10 of 14
  1. The dreaded wiper issue
    Jan 2006
    Southampton
    Well it looks like the spindle Assembly's have seized bad. Tried to press the spindle out but it's so tight we ended up making a right pigs ear of it. Luckily europatrs list a spare assembly complete. Should be here tomorrow.Anybody else had this problem? apparently it's very common
    Phaeton 3.0 LWB
    Lotus Carlton
    If you have to ask you wouldn't understand
  2. Question Re: The dreaded wiper issue
    Jul 2007
    Did it start with a squeak ?
    As I have a little squeak at the moment !
  3. Re: The dreaded wiper issue
    Jan 2006
    Southampton
    Afraid so. Wipers were also very jumpy
    Phaeton 3.0 LWB
    Lotus Carlton
  4. Re: The dreaded wiper issue
    dibly Guest
    Quote Originally Posted by Dozz View Post
    yes i have had this problem--also had to replace the linkage assy- takes about an hour to change the unit-not to bad to do, take out the tray between engine and wiper assy-the linkage is supposed to be lubricated regulaly or at least at service- i also tried to press out the spindles to no avail-i have never had any trouble ever in my life with wipers like this ,they must have very tight tolorences but i cant think why
  5. Re: The dreaded wiper issue
    Jul 2008
    I was suffering from the same problem but managed to fix it.
    This is how I did it, Use this method at your own risk and be careful of the moving parts whilst the wiper motor is running.
    Remove wiper arms
    Remove scuttle cover
    Run wipers, you can see which wiper post is siezed by looking to see if the wiper shaft bush is flexing on the end of the rack.
    Stop Wipers.
    Prise retaining c clip off wiper shaft and remove washer.
    replace wiper retaning nut loosly on shaft leaving plenty of thread.
    Start wipers and spray with lubricating oil (I used WD40)
    With the wipers running put a socket on the end of an extention bar on the nut and gently tap the wiper shaft into its bush.
    Keep spraying with oil.
    with the wipers still running carefully push the wiper shaft back into the bush.
    Keep pushing the shaft in and out of the bush and spraying with oil until you can move it by hand.
    stop the wipers.
    push the shaft all the way home in the bush and replace the washer and C clip.
    Reassemble the scuttle cover and replace the wiper arms
    Job Done
  6. Re: The dreaded wiper issue
    Somewhere on the A1 between Edinburgh and Leeds
    I had to have my wiper assembly replaced a while back so am keen to avoid this ahppening again. I am about to start servicing my car myself so will add this check to the list.
    What oil are you to use though. Too light an oil will wash out any grease and may actually make corrosion and seizure worse.
  7. Re: The dreaded wiper issue
    Jul 2008
    I Just used WD40 and it has been fine so far (6 months) but I am keeping and eye on the swept area and will try out a different lubricant if I need to do it again
  8. Re: The dreaded wiper issue
    dibly Guest
    well i didn't think of that--have been half stripping the outer linkage to get some oil in--not much room between parts so wd40 is a really good idea-- thanks for that--i will try that this weekend
  9. Re: The dreaded wiper issue
    Jul 2008
    Quote Originally Posted by mscomms View Post
    Remove wiper arms
    Stop Wipers.
    stop the wipers.
    Job Done
    I have just had to re-do this so it looks like it works for about a year using WD40, I would have removed the rack dissasmbled the assembly and greased it before reassembly but I didn't have time. The whole process only took me 40 minutes, 40 minutes per year aint too bad
  10. Re: The dreaded wiper issue
    Jul 2008
    if i have to do this again I will probably drill the bushes and fit grease nipples
  1. Audi A4 wiper arms - Aero wiper arms?
    By paul46 in forum Archive posts
    Last Post: 08-09-2007, 05:47 PM
  2. Air Con Issue
    By Audi Eire in forum Audi A3 - Archive Topics
    Last Post: 13-06-2007, 05:19 PM
  3. Dreaded water!!!
    By Dearg Doom in forum Passat - Archive Topics
    Last Post: 11-03-2007, 07:28 PM
  4. Dreaded Blue Smoke ....
    By Jabba in forum Passat - Archive Topics
    Last Post: 02-03-2007, 06:34 PM
  5. yet another issue
    By ktscarlet in forum Chat - Anything with wheels
    Last Post: 30-10-2006, 02:58 PM
