Thread: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
Page 14 of 29 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 289
  1. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Jun 2009
    Bexleyheath, England
    Any news Gup? and lets hope its good
    George
    1998 A6 Avant 2.5TDI AFB
    RETIRED @ 185K miles,
    2006 A6 Avant 3.0TDI BMK S Line Quattro retired due to RTC
    2009 S4 B8 Avant Stage 2 + DP EPL & TCU, big list of mods
    1 1 0
  2. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Sep 2011
    Lurking over a keyboard ...
    Before:-
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0040
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 02334 785 00200
    VCID: 254BDA7FECF6CC30723
    No fault code found.
    Readiness: 0 0 1 1 1
    After:-
    Part No SW: 4F0 910 401 A HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0020
    Coding: 0000000
    Shop #: WSC 06256 000 1048576
    VCID: 1A31F983D58873C8CF1
    When I got car back there was a fault logged...
    Coding: 0000000
    1 Fault Found:
    005650 - Engine Control Module Incorrectly Coded
    P1612 - 002 -
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: -195.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 10.34 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    Readiness: 0 0 0 0 0
    I have cleared it and it has not returned.... but coding before SVM Coding: 0011772 .... after SVM Coding: 0000000 ... so has dealer not coded ECU correctly
    Now before SVM ECU software P/N: 4F0 910 401 L rev 0040 ... now ECU software P/N: 4F0 910 401 A rev 0020 ... have I taken a step backwards
    Idle/Rev problem still exists
    Dealer has advised a MAF replacement... when asked if it will definitely solve issue the adviser replied most certainly but can not give guarantee...
    I feel demoralised
    IMO the sector which this car is pitched at is high end... is prestige motoring like this?
    I've gotta say hat's off to dealer as they have done 2-3 issues under goodwill... even today after saying per hour charge they lowered it substantially... they have offered MAF at discounted price than list... Genuine MAF List £255 offered at £225...
    When do I say enough is enough... so where do I go from here
  3. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Jun 2009
    Replace MAF, if it works bonus....if not then sell. As you have already said, "where do you draw the line?", this could be the nudge you need in either direction.
    George
    1 1 0
  4. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Sep 2011
    Thanks for support and viewpoint...
    I really can't believe there is something major wrong as engine/transmission looked so clean and leak free when viewed on removal... on ramp car viewing from below parts look so good for age/mileage...
    Yes everything I've removed and changed has been original... when doing retros viewing modules,etc all original...
    There are too many reasons as to why I like the A6 and the spec I bought... but looking at bills I've paid... bad choice... in my case...
  5. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Jun 2006
    Hey Gup, one step forward at least.
    No expert on module coding, all I can say is with my battery manager module that had all zeros on the original coding, it gave me no end of hassle, but as soon as I discovered it and coded it all was well. Different module of course but I suspect it should have a code.
    With the MAF, longshot but is yours the same part number as mine? If so happy to meet up and swap for a test. Could the dealer not install one as a test, you are paying them to fix things and not just guess after all - maybe they have a used car or spare part they could use for a quick test? Worth asking as it does seem a bit cheeky to say you will have to pay if it doesn't work.
    If it's the MAF then a result . If it is faulty, is it worth/an idea to clean it, nothing to loose.
    andy
  6. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by gupsterg View Post
    Before:-
    Coding: 0011772
    After:-
    Coding: 0000000
    Coding: 0000000
    1 Fault Found:
    P1612 - 002 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: -195.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 10.34 V
    Bin. Bits: 00101100
    Torque: 0.0 Nm
    I feel demoralised
    IMO unless you go exotic/supercar the sector which this car is pitched at is high end... is prestige motoring like this?
    the update wipes the code so recode it as the dealer is stupid (tpi states code may be lost)
  7. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Sep 2011
    Hi Andy,
    I asked can you test with new... sorry sir no stock... if dealer get one dealer say we are lumbered with it...
    But you would think they are going to have other cars that would require it?
    They would not supply data as to how the reached conclusion it is MAF... when doing MVB 07 10 18( Link:- Data post ) things like MAF/THROTTLE all look good...
    But again I'm just a meddling owner
    Last edited by gupsterg; 07-11-2012 at 01:36 PM. Reason: Formatting done, Post compacted :)
  8. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    May 2007
    knee deep in clunge
    14 Post(s)
    did they question where the info came from?
  9. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Sep 2011
    Yes... I said I can not disclose... I printed the one from my updated software...
    Shall I go check if I can code ECU with VCDS? I think it not gonna do as probably unsupported...
    So another visit tomorrow to dealer?
  10. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    May 2007
    knee deep in clunge
    14 Post(s)
    just paste the code or manualy enter into address 01 coding it will allow you to with vcds no problem
  1. Erratic Idle Revs
    By Padwick in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2011, 11:52 AM
  2. 1.6 SR 2000 8v Erratic Idle & Hunting
    By bloggs96 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2010, 11:06 AM
  3. 05 A4 2.0 tdi erratic revs
    By niall campbell in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-02-2009, 04:12 PM
  4. Please Help Hunting at idle .......and struggling at low revs.........
    By hornetcarp in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2008, 05:32 PM
  5. Idle erratic, revs dont come down quick when come to a stop!
    By enright86 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2008, 02:39 PM
