Thread: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
Page 10 of 29 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 289
  1. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #91
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by a8 tech View Post
    tip if you disconnect the airmass it will deactivate egr so try starting it with the airmass unplugged and see what happens
    Will expand what happened later ... but can you tell me what Ohms readings should I be getting to check MAF... thanks
    Looking at the post... Link:- audi 3.0tdi engine measurement blocks
    Is the above MVB 10 something to look at as well
  2. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #92
    May 2007
    knee deep in clunge
    14 Post(s)
    Off the top of me head no, however you could check actual and specified with vcds but remember if the engine idles for to long egr will kick in and alter the values so rev it frequently for a true value
    If the egr is playing up you should be able to see a constant out of tolerance airmass reading
    If the airmass is ok and egr ok then your back to injection deviation from either worn injectors or pressure in the rail but thats easy to check by looking at mvb's for actual line pressure
    If the pressure is ok then again you are left with the injectors or compression loss
    Now if the injectors are removed the brass O ring must be replaced as this compresses when re tightened and could allow blow pass compression leakage
    also each injector is calibrated to the ecu and therefore if replaced should be set up but for simple swapping around to eliminate it should be fine
    3.0l V6 TDI (BKS/BMK/BUN) - Ross-Tech Wiki
    Again all speculation but pointing you in the right direction
  3. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #93
    Arundel
    Better the devil you know?....sorry I havn't read the whole thread, have you taken it to Audi to see what their view is?
  4. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #94
    May 2007
    knee deep in clunge
    14 Post(s)
    lol
    0 2 0
  5. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #95
    Sep 2011
    I'm trying to exorcise the devil...
    A8 is > than dealer
    1 1 0
  6. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #96
    Arundel
    Ah sorry had no idea!....
    0 2 0
  7. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #97
    Sep 2011
    Ok guys... since about 11 am today... Zesty the A6 is
    On first start of day/road test without MAF harness connected... there was rockying after the normal rock of cranking of engine... revs fluttered but very quickly sorted themselves out way better than before/quicker
    Whilst on TD... stopped when temp reach 70c ish... started her up =
    Then when she reach normal temp (90c ish)... stopped/started her up =
    Came home... stopped/started... all well... at no point did I see idle smoke at start up/driving/stopping & checking... so I believe the one in video may have been throttle/maf related or just normal morning thing... but today and other day when she no smoke temps been low...
    Then I let her cool... when she reach between 90/70 line, start her up = ... then let her cool between 70/50, start her up =
    Then rang for best prices on MAF... but will wait until get info on doing Ohms test on MAF...
    Then went to do my usual trips... on all starts ... surprising thing was usually with MAF I thought power loss was a sign of one gone or going...
    But Day 1 with Zesty the A6! having no MAF connected been a full success IMO...
    The MIL light came on
    Did scan these were the faults...
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 401 L HW: 4F0 907 401 A
    Component: 3.0L V6TDI G000AG 0040
    Revision: --H01--- Serial number:
    Coding: 0011772
    Shop #: WSC 02334 785 00200
    VCID: 254BDA7FECF6CC30723
    2 Faults Found:
    16488 - Mass Air Flow Sensor (G70)
    P0104 - 001 - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 234.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 80.9 %
    Voltage: 11.02 V
    Absolute Pres.: 999.6 mbar
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 13.5°C
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 001 - Signal too Low
    Freeze Frame:
    RPM: 882 /min
    Torque: 113.1 Nm
    Speed: 0.0 km/h
    Duty Cycle: 80.9 %
    Voltage: 11.93 V
    Absolute Pres.: 1009.8 mbar
    Mass Air / Rev.: 481.8 mg/str
    Temperature: 11.7°C
    Readiness: 1 2 0 0 0
    As I've been doing so many videos... runs with laptop checking & logging MVB's...
    I've now not done any MVB's on the MAF... so tomorrow going to clears faults before she go for MOT, so no MIL and connect MAF back...
    If problem return which I think it will... will disconnect... again!
  8. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #98
    May 2007
    knee deep in clunge
    14 Post(s)
    Ok so now we can look at the possible cause
    Egr flow excessive, poor air mass, poor air filter, fuel unbalanced
    Remember disconnecting maf turns off egr regulation and defaults fuel mapping
    Still no party just closer
    See Mass Air / Rev.: 481.8 mg/str default value very high and will make the running smoother because you have no dirty egr gas going back into the cylinders
    Note:> To all watching this thread, I answer on the fly and have yet to actually sit down and study the data so please do not think my diagnosis is 100% spot on because its not and i am just trying to move this on a little quicker than it has been and give options for better diagnosis route
    and i dont have the vehicle in front of me which would help
  9. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    #99
    Sep 2011
    Air filter new... genuine.. done in Jan by me.. I owe you a visit with a hamper of goodies
  10. Re: BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! )
    Aug 2012
    East Sussex, UK
    Sounds like progress Gup, keep at it it
    2006 (C6) A6 Avant SE. 3.0 TDI V6. Quattro. 6 Speed Manual. Adaptive Air Suspension.
    1 1 0
  1. Erratic Idle Revs
    By Padwick in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-12-2011, 11:52 AM
  2. 1.6 SR 2000 8v Erratic Idle & Hunting
    By bloggs96 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-07-2010, 11:06 AM
  3. 05 A4 2.0 tdi erratic revs
    By niall campbell in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-02-2009, 04:12 PM
  4. Please Help Hunting at idle .......and struggling at low revs.........
    By hornetcarp in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2008, 05:32 PM
  5. Idle erratic, revs dont come down quick when come to a stop!
    By enright86 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2008, 02:39 PM
