Thread: obd port on 1998 a4 cabriolet
  1. obd port on 1998 a4 cabriolet
    Jul 2008
    Hi does anyone know the location of the OBD port on a 98 a4 cabriolet. I have a OBD2 code reader I hope its the same port and not the old style. Thanks all
  2. Re: obd port on 1998 a4 cabriolet
    46 Post(s)
    Quote Originally Posted by galva View Post
    Have a nosey here - VAG-COM/OBD Port locations not sure if your car was before they time they all moved to above the accelerator pedal but look there too.
  3. Re: obd port on 1998 a4 cabriolet
    Aug 2011
    Meath
    I'm not 100% sure but I think the cabriolet had the 2 plug dlc under the bonnet on the drivers side?
  4. Re: obd port on 1998 a4 cabriolet
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Just to avoid confusion to anyone reading this thread, the 1998 cab/convertible is known as just that, 1998 con/cab, as based on the B4/80 model.
    This car is not an A4 cab/con, the 80 cab/con ran up to 2000, whereas the A4 cab/con started 2002.
    Not being smart but wouldn't want anyone giving the original poster info relating to A4 rather than 80/B4.
    I am only guessing but I think the earlier cars were the old style diagnosis set up when the later (A4) would be OBD1/11
    Hope that was at least a little bit helpful
    Stuart
  5. Re: obd port on 1998 a4 cabriolet
    Aug 2011
    Meath
    It's called a Data Link Connection
  1. Question OBD Port - Diagnostic scanners
    By wigs_1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2012, 09:24 PM
  2. OBD Port
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2010, 02:33 PM
  3. OBD port on 1996 T4 ?
    By Ali baba in forum The Commercial Range
    Last Post: 14-08-2008, 08:35 AM
  4. Obd Port
    By glen poole in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-03-2008, 04:50 PM
  5. Obd Port For Vag Com
    By anilnickypatel in forum Golf MK3 - 1993 - 1999
    Last Post: 15-11-2007, 10:34 PM
