Thread: How to recalinrate steering wheel slip ring. fault code 01826
  1. How to recalinrate steering wheel slip ring. fault code 01826
    Mar 2007
    nr Gloucester
    I took the steering wheel off earlier to change something. I put it back together and now have the above fault code. I know I need to recalibrate the steering angle sensor. Can someone tell me how. I have VCDS lite - is it possible with this version? Fault below...
    VCDS-Lite Version: Release 1.1
    Monday, 01 October 2012, 18:18:03:59949
    Control Module Part Number: 8E0 614 517 04255
    Component and/or Version: ABS/ESP front 1726
    Software Coding: 04255
    Work Shop Code: WSC 00000
    VCID: E5BD58BA6C6F
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    I'd like to get this done this evening as i dont fancy driving the car with no ESP!!
    Skid... spin... tree... hospital!!
    Thanks in advance.
    Adam
    Audi A6 (C7) 3.0 BiTDi Black Edition 2016
  2. Re: How to recalinrate steering wheel slip ring. fault code 01826
    46 Post(s)
    before removing the steering wheel you shouldve known to tape the slip ring position first rule
    i cant gain access to Rosstech website for some reason but as soon as its working again ill post the fault diagnosis.
    wiki.ross-tech.com/index.php/01826
    try turning your steering wheel lock to lock a few times then drive in a straight line ... it could clear itself.
  3. Re: How to recalinrate steering wheel slip ring. fault code 01826
    Mar 2007
    nr Gloucester
    Thanks Chris
    I think the ross tech site is down - been trying to get on for a while now! Anyway, just took it for a spin and it seems to have sorted itself - phew!
    Just for my reference, how do you tape up the slip ring - before you remove the steering wheel?
  4. Re: How to recalinrate steering wheel slip ring. fault code 01826
    46 Post(s)
    you dont - you need to tape it when the wheel is removed (i constructed my reply wrong) with insulation tape at 9pm/3pm and 6pm positions
  5. Re: How to recalinrate steering wheel slip ring. fault code 01826
    Mar 2007
    nr Gloucester
    Duly noted. Thanks
  6. Re: How to recalinrate steering wheel slip ring. fault code 01826
    46 Post(s)
    by the way everytime you disconnect the battery you will get an esp fault relating to the above - just do the lock to lock and a short drive and it will clear.
    remember to tape the slip ring too
  1. Solved How to cure whining noise from steering wheel slip ring?
    By toff in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2016, 03:57 PM
  2. Question Slip ring-steering sensor question (MFSW retrofit)
    By vsheremeti in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-01-2011, 07:05 PM
  3. A4 slip ring squeaky steering wheel
    By portovechios in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2010, 05:42 PM
  4. Error Code 01826-032 Steering Sensor...
    By randall977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-01-2010, 11:40 AM
  5. Airbag slip ring/steering angle sensor replacement
    By young dub in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-11-2009, 02:21 PM
