Thread: DPF warning light won't turn off
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. DPF warning light won't turn off
    Aug 2012
    London
    Hello ppl... My DPF light came on Monday evening on my way home.., once I got home did my research and on the Tuesday drove the car at higher revs to try and burn it off.. Nothing..on my way home yesterday I put wynn's DPF cleaner into the tank ant half a tank drove at high revs and still nothing... This morning I kept it at 4th or 5th between 2-2.5k revs all the way to work which includes dual carriage way and m25 and still nothing... Any suggestion... I called Audi garage near my work place and they can't see me till Tuesday.. Anyone recommend an Audi specialist near Croydon??
  2. Re: DPF warning light won't turn off
    Jul 2008
    West Yorkshire
    Hi are there any other lights on or just the dpf light.
    if no other lights are on then to do a proper regen you would need to take the car on a motorway and leave it in 4th gear at around 2.5k constantly for around 20 mins hope this helps
    Mod Edit - changed to sentence case.
  3. Re: DPF warning light won't turn off
    Aug 2012
    HEREFORD
    remove the dpf before it damages the turbo
  4. Re: DPF warning light won't turn off
    129 Post(s)
    1972 Post(s)
    DPF's do not damage turbo's, they are downstream!
    Your car will need a fault code read as it may have a faulty DPF pressure sensor and it may also need a forced regeneration and again this requires a diagnostic computer.
  5. Re: DPF warning light won't turn off
    Aug 2012
    London
    so i got the issue sorted by getting a regen done my specialist... its been two days and the light is back on... any ideas or shall i get it removed and remaped.. anyone used JF Automotive ???
  6. Re: DPF warning light won't turn off
    129 Post(s)
    1972 Post(s)
    We would need to see the ASH MASS figure (not soot) to make that sort of decision.
  7. Re: DPF warning light won't turn off
    Aug 2012
    London
    Jus spoke with my mechanic.. He told me I used the wrong oil for the service.. I used mobile one thought that would be best so advised me to chand oil and filter and try regen on motor way...
  8. DPF warning light won't turn off
    46 Post(s)
    Did you supply the oil or did he recommend it?
  9. Re: DPF warning light won't turn off
    Aug 2012
    London
    Unfortunately I supplied it... :-( but lesson learnt
  10. Re: DPF warning light won't turn off
    Aug 2012
    London
    How can u tell if the sensor is gone?
  1. Service Warning Light - How do I re-set it / turn it off?
    By Dan Glibitz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2012, 04:32 PM
  2. A3 1.9 TDIe 2007 DPF warning light
    By PeteA3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-07-2011, 02:13 PM
  3. Attention DPF Warning Light
    By JBlues in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-06-2010, 07:32 PM
  4. How To Turn off airbag warning light
    By vw_craig in forum Golf MK4 - 1999 - 2004
    Last Post: 08-12-2009, 10:56 PM
  5. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
