Thread: Warbling noise - crankshaft pulley (i think)
Results 1 to 10 of 16
  1. Warbling noise - crankshaft pulley (i think)
    Dec 2011
    Swindon
    9 Post(s)
    2012-08-12 14.08.34.jpgCircled in red is the housing for the crankshaft pulley, on the drivers side part of the engine. Between 1000 and 2000 RPM under load and on idle, there is a very noticeable warbling noise like a bird, it is more noticeable when driving and the RPM's reduce. The timing belt was changed in February 2012 with a new tensioner and metal water pump. I am informed that the pulley/cog has gone and might need replacing.
    Is this a good diagnosis or could it be more serious?
  2. Re: Warbling noise - crankshaft pulley (i think)
    Jan 2009
    towcester northants
    never known the pulley go!
    i would suspect that the belt tension is too tight or whoever done the job for you didnt fit a kit and the tensioner or idlers are noisy?
  3. Re: Warbling noise - crankshaft pulley (i think)
    Dec 2011
    Swindon
    9 Post(s)
    it was fitted with a kit
  4. Re: Warbling noise - crankshaft pulley (i think)
    Aug 2011
    Meath
    It could be the alternator pulley its easy to check. Take of the aux belt and put a lollypop stick or pencil etc into the alternator to jam the blades. turn the pulley both ways it should turn anti-clockwise only when vied from the belt end. if won't turn both ways the pulley should be replaced
  5. Re: Warbling noise - crankshaft pulley (i think)
    Dec 2011
    Swindon
    9 Post(s)
    Paul, you said it should only turn anti-clock wises, then say if wont turn both ways the pulley should be replaced???? do you mean with and with out the lollipop stick in it?
  6. Re: Warbling noise - crankshaft pulley (i think)
    Aug 2011
    Meath
    The stick, pencil or whatever is used to jam the alternator. then try to turn the pulley it should turn anti-clockwise but not clockwise as you look at the pulley face on. you don't need much force it either turns or the clutch inside it is toast. I use a stick, really an ice lolly stick, so i don't have to disconnect the battery which you should do really
  7. Re: Warbling noise - crankshaft pulley (i think)
    Dec 2011
    Swindon
    9 Post(s)
    if it werre the alternator pulley, would the battery not charge properly, as this all seems fine?
  8. Re: Warbling noise - crankshaft pulley (i think)
    131 Post(s)
    1973 Post(s)
    That is the camshaft pulley and it sounds like the belt has been set too tight, I hear these coming in the car park and know immediately what it is-its one of those noises like failed alternator pulleys, you just know.
  9. Re: Warbling noise - crankshaft pulley (i think)
    Dec 2011
    Swindon
    9 Post(s)
    Crasher, i have some video with the sound in it but i cant upload it on this site. Got my bushes today, cheers.
  10. Re: Warbling noise - crankshaft pulley (i think)
    131 Post(s)
    1973 Post(s)
    I followed the order through to make sure it was right. The noise is really distinctive but I find it hard to analogise. I know it when I hear it.
  1. 16v polo crankshaft pulley
    By dabsline in forum Polo - Derby - Lupo - Fox
    Last Post: 29-01-2011, 04:53 PM
  2. loose crankshaft pulley
    By popsafety in forum The Commercial Range
    Last Post: 21-09-2009, 11:11 PM
  3. Please Help Wobbly crankshaft pulley.
    By AndySil in forum Golf MK2 - 1984 - 1992
    Last Post: 14-03-2009, 12:15 AM
  4. Tdi (AFN) crankshaft pulley removal
    By fantasiagreen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-06-2008, 12:14 AM
  5. VW Transprter Crankshaft pulley removal
    By Beetlefan in forum The Commercial Range
    Last Post: 20-03-2008, 06:50 PM
