Thread: Super VAG +
Results 1 to 10 of 17
  1. Super VAG +
    Aug 2011
    Meath
    Has anyone any experience of the Super Vag code scanner? I'm tempted to upgrade my old Autel as i cant get it to upgrade. All advice read but not all advice taken!
  2. Super VAG +
    46 Post(s)
    Buy vcds - you won't be disappointed.
  3. Re: Super VAG +
    Aug 2011
    Meath
    Thats good advice I took from this website some time back. I would like a modern portable scanner as I now need an extension lead to work the laptop in the car this is somewhat limiting if i go to scan a car
  4. Re: Super VAG +
    Ambler, PA, USA
    Quote Originally Posted by paulkennedy View Post
    Coming Soon: VCDS Mobile
    2 0 0
  5. Re: Super VAG +
    Oct 2005
    Please don't contact us to ask whether you can be a tester. These are all spoken for already.
    Bugger Cannot wait for this - good luck with the testing!
  6. Re: Super VAG +
    Aug 2011
    Meath
    Quote Originally Posted by bearthebruce View Post
    Hi Bruce
    if VCDS mobile works with an android phone will it work with android tablet?
    thanks
  7. Re: Super VAG +
    Ambler, PA, USA
    The intent is that VCDS-Mobile will work with any device that can work by a wifi connection using a web browser. At this point, I do not have a list of compatible devices nor limitations. I know that it has been tested on Android phones, iPhones, IPads, Windows phones, Nooks, and a whole host of other devices. So, my expectation is that Android tablets will be able to talk with our new device when it arrives in 2014.
    Last edited by bearthebruce; 13-12-2013 at 11:41 PM. Reason: Edited the date...... :(
  8. Re: Super VAG +
    Dec 2011
    Southsea, United Kingdom
    Hi there.
    VCDS has it's place. Can it read your SKC? Nope.
    There are two versions of SuperVAG, one in a dark case and one in a light blue one, I'd look at the light blue, newer one. You can perform diagnostics, mileage adjustment if you change your cluster (it can often be cheaper in time to replace the cluster with a repaired one if your DIS is screwed) and they're self powered, rather than requiring a laptop.
    Oh, and it's cheaper than a genuine copy of VCDS.
    thanks,
    Jonathan
  9. Re: Super VAG +
    Aug 2011
    Meath
    Thanks mate I'll take a look
  10. Re: Super VAG +
    Nov 2012
    Quote Originally Posted by jtonthebike View Post
    Hi there.
    thanks,
    Jonathan
    I am also looking to buy the SuperVAG Professional Super VAG K+CAN V4.8 OBD2 Code Scanner for VW Audi Ship from UK | eBay in the hope that I can read my SKC code and program a new key (this one):
    AUDI FLIP KEY FOB REMOTE, A2,,A4, A6 3 BUTTON 4D0 837 231 A | eBay
    Am I looking at the right thing, would this be able to do what I want and then be useful as a vehicle diagnostics tool if needed in the future?
    By the time I've programmed one key it has paid for itself and saved me £50, so I reckon it's worth a try? Looks/sounds like just what I need! I have used diagnostic equipment before, on a TD5 Land Rover, and this looks to be a similar sort of thing. I have never programmed keys before though.
    Thanks, Martin
  1. what about the super vag k can plus 2.0??
    By andylu in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 17-10-2011, 12:11 PM
  2. Super Vag v4.8 & beetle 1.6 pin code
    By actionman in forum Beetle 2000-
    Last Post: 16-10-2011, 11:31 PM
  3. SUPER VAG K+CAN problem with Audi A3
    By Vaghead in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 21-01-2011, 02:00 PM
  4. super vag diagnostic tool
    By fil1973 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 11-03-2010, 10:15 PM
