Thread: Golf mk4 all electric windows not working!
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Golf mk4 all electric windows not working!
    Sep 2012
    Gb
    I just bought my golf mk4 gt tdi 2000 plate knowing the electric windows were not working and assuming that it was a motor fault, when i press the switch the motor clicks twice (like a relay switch) but no movement, this happens on all 4 windows, so far i have tried a different motor in the drivers side and that does the same thing, i have also checked the car to door wiring connector for any signs of decay or rust and they are perfect, i am assuming that the fuses are ok as the rcl works and the interior lights are working and thrre must be power going thru to the motor to make the clicking noise?
    Has anyone had this problem before and found a fix? Please help as its driving me mad!
  2. Re: Golf mk4 all electric windows not working!
    Dec 2011
    Swindon
    9 Post(s)
    Have you taken the door card off to see if the motor is turning, turning the cable winder on the window regulator etc? It seems odd that all 4 windows are not working. I might be the CCM unit (electronic box of tricks). This might be identified with a VAG COM / VCDS scan... which might show fault codes relating to it.
  3. Re: Golf mk4 all electric windows not working!
    Sep 2012
    Gb
    Hi geoff, yes tried all that, yesterday i had to take out the passenger seat because of flooding caused by water coming thru the pollen filter housing (think its the seal) the soundproofing underneathe was soggy with an inch of water! Anyway while i had this out i checked the wiring harness more thouroughly and while it was wet there were no breaks in the wires and the plug areas were dry, strange thing is that when i put the ignition on after reconnecting the battery the back two windows worked once down and back up again Then nothing?? i think the next step is a diagnostic check like you said. Alas, more money :-(
  4. Re: Golf mk4 all electric windows not working!
    Oct 2005
    Did you open the CCM?
    Try here for a local VCDS user who may be able to assist for mere beernuts;
    VCDS - Help Requests
  5. Re: Golf mk4 all electric windows not working!
    Sep 2012
    Gb
    Not opened the ccm yet but does this control the windows and if so what would i be looking for?
  6. Re: Golf mk4 all electric windows not working!
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by Graywd View Post
    This.
    Nothing to see here, move along..
  7. Re: Golf mk4 all electric windows not working!
    Oct 2005
    ^ That.
    If your carpet was wet, chances are the CCM has been submerged for some time.
  8. Re: Golf mk4 all electric windows not working!
    Sep 2012
    Gb
    Is the ccm underneath the passenger seat on a golf? Only thing i found there was a small blue box with a single plug connection, this was soaked with water however maybe this has something to do with it?
  9. Re: Golf mk4 all electric windows not working!
    Dec 2011
    Swindon
    9 Post(s)
    I think the CCM is located in the drivers door behind the window regulator plate. something i need to change sometime
  10. Re: Golf mk4 all electric windows not working!
    Oct 2005
    I'm an idiot (and so is Hex). I see CCM I immediately think Passat. Sorry!
    The CCM on a mkiv Golf is in the dash. Access is via removal of the knee bolster.
  1. Replies: 7
    Last Post: 14-04-2009, 01:15 AM
  2. Question electric windows not working mk5 golf
    By powerball in forum New Member Introductions
    Last Post: 06-04-2009, 03:29 AM
  3. help me MK4 central locking and electric windows stopped working
    By bevstical in forum Golf MK4 - 1999 - 2004
    Last Post: 28-01-2009, 10:50 PM
  4. Electric Windows and lock not working - golf
    By bainsy2 in forum Octavia
    Last Post: 27-09-2007, 09:33 AM
  5. VW Golf Mk4, electric windows problem??
    By churd_smith in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2007, 07:26 AM
