Thread: a3 high pressure sensor g65 location
Results 1 to 10 of 10
  1. a3 high pressure sensor g65 location
    Jul 2011
    blackwood
    the econ button is on in my car and cant get aircon
    ive put a computor on it and its saying
    high pressure sensor g65 open
    sensor air quality open
    anyone else has this and where are they located to change?
    thanks
  2. Re: a3 high pressure sensor g65 location
    Jul 2011
    blackwood
    anyone
  3. Re: a3 high pressure sensor g65 location
    Southern County Softy
    20 Post(s)
    Do you have the fault code?
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  4. Re: a3 high pressure sensor g65 location
    Jul 2011
    blackwood
    00819
  5. Re: a3 high pressure sensor g65 location
    20 Post(s)
    Just checked the codes on Rosstech.
    The first one I couldnt find.
    The second suggests a regass as a starting point .
    If that doesn't work change the sensor
  6. Re: a3 high pressure sensor g65 location
    Jul 2011
    blackwood
  7. Re: a3 high pressure sensor g65 location
    20 Post(s)
    I think the pressure sensor is located in the air-conditioning compressor.
  8. Re: a3 high pressure sensor g65 location
    Jul 2011
    blackwood
    so the compressor may be scrap?
  9. Re: a3 high pressure sensor g65 location
    20 Post(s)
    No, If it senses low pressure the compressor won't cut in,that's why your econ light is on .
    the switch could be faulty and it can be changed.
  10. Re: a3 high pressure sensor g65 location
    Jan 2012
    Coding Something
    G65 is located on the aircon piping according to the etka diagram, to the right of or just behind right side of rad area, which I suspect either your refrigerant is low & needs regassing or sensor swapout, you'd need to drain system 1st before swapping out, also check its actually plugged in.
  1. G65 a/c refrigeration pressure sensor
    By matthewgdavies in forum Alhambra
    Last Post: 10-08-2021, 02:14 PM
  2. How To Change the G65 Aircon Thrust/Pressure Sensor
    By Major Clanger in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-07-2018, 11:08 AM
  3. G65 air con High Pressure Sensor - vw part number?
    By greg123 in forum Golf MK5 - 2004 - 2009
    Last Post: 07-07-2018, 11:19 AM
  4. high pressure sensor G65 ??
    By MPJ in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-12-2008, 01:46 PM
  5. Question Correct location of low and high oil pressure switches?
    By misc1 in forum 80 - 90
    Last Post: 02-09-2008, 09:17 AM
