Thread: Help. engine light, auxiliary coolant pump
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Help. engine light, auxiliary coolant pump
    Jun 2011
    Drogheda Ireland
    I had an engine light on the car this evening and plugged in the VCDS to see what it was about. I got the following fault:
    Sunday,09,September,2012,20:22:26:27301
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Address 01: Engine Labels: 03L-906-022-CAG.clb
    Control Module Part Number: 03L 906 022 FH HW: 03L 906 022 FG
    Component and/or Version: R4 2,0L EDC H01 6418
    Software Coding: 0105002C02072120
    Work Shop Code: WSC 00503 210 88548
    ASAM Dataset: EV_ECM20TDI03L906022FH A01009 (AU56)
    VCID: 70E5EAF2ABC9B698D15
    1 Fault Found:
    4875 - Coolant Pump 2
    P261A 00 [172] - Open Circuit
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 91996 km
    Date: 2012.09.09
    Time: 14:19:00
    Readiness: 1 1 0 0 0
    So the Sunday,09,September,2012,20:22:26:27301
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 91996 km
    Date: 2012.09.09
    Time: 14:19:00
    The Sunday,09,September,2012,20:22:26:27301
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Mileage: 91996 km
    Date: 2012.09.09
    Time: 14:19:00
    I cleared the code and went back into fault codes and it was back, so I believe it needs to be replaced....
    Are these expensive to buy from audi or would you buy else where? Awkard to fit?
    Any advice would be appreciated.
    VW CC GT 177 DSG
  2. Re: Help. engine light, auxiliary coolant pump
    Sep 2011
    Lurking over a keyboard ...
    Any more info?
    Looking at your log/guessing is it a 2.0 TDi? CAGB engine code? as yours facelift A6...
    Is car overheating? if coolant pump failing on other cars owned seen they drip/leak as sign of imminent failure...
    As pump mechanical my opinion as meddler/owner ( ) that it may be a electronic control valve or something on cooling circuit??
  3. Re: Help. engine light, auxiliary coolant pump
    Model year and engine code required. It sounds like you have a faulty over-run coolant pump. Regards Peter
    1 1 0
  4. Re: Help. engine light, auxiliary coolant pump
    Jun 2011
    Drogheda Ireland
    Quote Originally Posted by Peter D View Post
    Hi Peter,
    Its a 2009 S Line 2.0 tdi 170 CR with multitronic, engine code CAHA. I havent had any coolant loss or noticed any leaking so far, I cleared the code and started the engine and the engine warning light remained off this time but when I checked for the fault code again it came back.
    VW CC GT 177 DSG
  5. Re: Help. engine light, auxiliary coolant pump
    Jun 2011
    Drogheda Ireland
    Quote Originally Posted by gupsterg View Post
    Any more info?
    Hi Gupsterg,
    Its a CAHA enging code on a facelifted model (2009) No leaks or drips noticed. I haven't had any overheating problems either.... Might require a trip to Audi.... I have vcds if anyone knows how I should go about trouble shooting this....
    Pics attached of what I believe to be the auxiliary pump, as I said no coolant loss or leaks found
    VW CC GT 177 DSG
  6. Re: Help. engine light, auxiliary coolant pump
    Jun 2011
    Drogheda Ireland
    Any ideas?
    VW CC GT 177 DSG
  7. Re: Help. engine light, auxiliary coolant pump
    Sep 2011
    I seen that in EPC will get you a price.... this updates monthly but my SG is little out of date I have update for it will install and check for facelift car...
    I think the photos really help i) for you ii) for another which will come across thread to get help, good posting
  8. Re: Help. engine light, auxiliary coolant pump
    Jun 2011
    Drogheda Ireland
    Can anyone tell me what the part number and if possible cost of a replacement auxiliary pump for my engine code?
    VW CC GT 177 DSG
  9. Re: Help. engine light, auxiliary coolant pump
    Sep 2011
    P/N 03L 965 561 approx. £116
    For 2.0 TDI engine codes CAGB, CAHA, CAHB
  10. Re: Help. engine light, auxiliary coolant pump
    Jun 2011
    Drogheda Ireland
    Thanks gupsterg. Do you know what the difference between the two pumps? Different design? Is one more reliable than the other?
    VW CC GT 177 DSG
  1. V5 Auxiliary Water Pump question...
    By deserthawk in forum Bora - 1998 - 2005
    Last Post: 26-01-2017, 05:26 PM
  2. Engine management light + coolant sensor
    By Mcpickering in forum Golf MK4 - 1999 - 2004
    Last Post: 25-10-2009, 10:21 AM
  3. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
  4. Auxiliary water pump replacement...
    By webchem in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-10-2008, 10:35 AM
  5. Engine Managment light-Coolant leak
    By pembo1976 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2007, 07:23 AM
