Thread: Cabin air filter on 2010 A3 TDI
Results 1 to 10 of 12
  1. Cabin air filter on 2010 A3 TDI
    Sep 2012
    South of BC
    This filter is located in the engine compartment. What I don't know how to do is removing the cowling to get to the cabin air filter. It appears that I need to remove the wipers but there is something else holding it to the windscreen, and I don't want to force it and breaking it.
    Thanks for advice.
  2. Cabin air filter on 2010 A3 TDI
    46 Post(s)
    Pollen filter or the actual air filter?
    Air filter housing is located just on front of the battery.
    Pollen filter can be seen with the removal of the glovebox.
  3. Re: Cabin air filter on 2010 A3 TDI
    Sep 2012
    South of BC
    It's the pollen filter located in the engine compartment below the cowling. I just can't get the cowling off. I don't want to break it and I don't see how it is secured
  4. Cabin air filter on 2010 A3 TDI
    46 Post(s)
  5. Re: Cabin air filter on 2010 A3 TDI
    Sep 2012
    South of BC
    This one is accessed from the engine compartment NOT from the glovebox. I know because I took all 9 screws out to drop the whole glove box area. After all that I called the service department and they said its in the engine compartment. I didn't realize I would run into a problem trying to get the cowling off, otherwise I might have asked, but I might not have gotten an answer, other than "bring it in"
    Audi S3 / Audi A3 Type 8L DIY: Replacing the Cabin Air Filter/Pollen Filter
    You get it from the glovebox
    Question A3 Pollen Filter airflow direction
  6. Cabin air filter on 2010 A3 TDI
    46 Post(s)
    The link you have provided is for the old a3
    It's in behind the glovebox as per my link.
  7. Re: Cabin air filter on 2010 A3 TDI
    Sep 2012
    South of BC
    I have a 2010 and even though that's an older A3, I just wanted to indicate that the placement of the pollen filter is in the engine compartment, not as everyone thinks is just below the glove box. Most vehicles make it easy and put it below the glovebox, but not certain models. I have seen it also on a VW GTI as well.
  8. Re: Cabin air filter on 2010 A3 TDI
    Apr 2010
    staffordshire
    The pollen filter on every 2010 A3 is just behind the glovebox (glovebox doesn't need removing), remove the felt/poly trim, then slide the plastic cover out, the filter can then be pulled down!!!!
    1 1 0
  9. Cabin air filter on 2010 A3 TDI
    46 Post(s)
    Quote Originally Posted by baylissboy View Post
    the pollen filter on every 2010 a3 is just behind the glovebox (glovebox doesn't need removing), remove the felt/poly trim, then slide the plastic cover out, the filter can then be pulled down!!!!
    thank you!!!!!!!!!
  10. Re: Cabin air filter on 2010 A3 TDI
    Mar 2010
    saltash uk
    @Chris, is it in the same position as per my A6? And are the filters the same?
    Just a quick question that I though you would know the answer to.
    Thanks in advance.
    2009 Audi A6 Avant 2.0L Tdi
    2010 Audi A3 2.0L Tdi
  1. Cabin Air/pollen filter. Where is it on UK-spec car?
    By bruce1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-06-2013, 07:30 PM
  2. cabin pollen/ air filter
    By winnie070383 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-07-2011, 12:18 PM
  3. how to remove passat 07 cabin air filter
    By beso in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-07-2010, 10:12 AM
  4. Air cabin filter/Pollenfilter
    By mikifaca in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-03-2010, 11:30 PM
  5. Cabin air filter
    By Nick SR in forum Bora - 1998 - 2005
    Last Post: 09-07-2008, 08:21 PM
