Thread: ABS Fault - 2003 Passat TDI
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. ABS Fault - 2003 Passat TDI
    Aug 2007
    Hi folks, I really hope someone can help solving this fault as it's driving me nuts now. A couple of weeks ago I had the "Check Brake Pads" light come on and off intermittently so I changed the front pads and discs as they were due for it. When I put it all back together I wound up with the ESP and ABS amber warning Lights lighting up constantly then as I'd drive off the red handbrake warning light came on and stayed on.
    I had followed the Haynes manual to do the brakes except I missed the step where it suggests opening the bleed nipple when pressing the caliper pistons back into the caliper so I thought that maybe I had knackered the Pressure switch.
    I have since bought a second hand ABS pump and control unit. I swapped the ABS controllers, re-coded it no problem but... no change.
    Checked all of the fuses in the car and under the steering wheel area under the dash panel, no problems.
    Then I have carried out a full bleed of the brakes, no change.
    Then I have swapped the hydraulic unit (which had my cars original control unit fitted to it), re-coded the control unit again no problems but... no change.
    VAG COM has consisently given and still gives the
    Address 03: ABS Brakes
    1 Fault Found:
    01200 - ABS Valves Supply Voltage
    35-00 - -
    fault message and I am at the end of my tether as to what to do next.
    Any suggestions welcomed.
    Full VAG COM Print in the next post.
  2. Re: ABS Fault - 2003 Passat TDI
    Aug 2007
    As I mentioned here's the full VAG COM autscan log:
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Wednesday,05,September,2012,19:56:07:22761
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ3E315444 Mileage: 191000km/118681miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 GQ
    Component: 1,9l R4 EDC 0000SG 1582
    Coding: 00002
    Shop #: WSC 05314
    VCID: 6CD93CCA1CD31E78EDD
    WVWZZZ3BZ3E315444 VWZ7Z0B6639948
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 04255
    Shop #: WSC 12345
    VCID: 254F09EEBFB9EF30723
    1 Fault Found:
    35-00 - -
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 J
    Component: CLIMATRONIC B5GP 0006
    Coding: 17000
    Shop #: WSC 05311
    VCID: 285100DAC8ABF258495
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 C
    Component: 08 AIRBAG VW61 04 0001
    Coding: 12344
    Shop #: WSC 05311
    VCID: 244914EAB483163865D
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 927 A
    Component: KOMBI+WEGFAHRSP VDO V08
    Coding: 05415
    Shop #: WSC 00535
    VCID: 234B17F6B18D11001C7
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05311
    VCID: F0E1A8BAB0FB7A98515
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 8Q Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 05311
    VCID: 366DDEA2121F94A8CB9
    Subsystem 1 - Part No: 1C2959802
    Component: 8Q Tőrsteuer.FS KLO 0009
    Subsystem 2 - Part No: 1C2959801
    Component: 8Q Tőrsteuer.BF KLO 0009
    Subsystem 3 - Part No: 1C0959811
    Component: 8Q Tőrsteuer.HL KLO 0009
    Subsystem 4 - Part No: 1C0959812
    Component: 8Q Tőrsteuer.HR KLO 0009
    2 Faults Found:
    01135 - Interior Monitoring Sensors
    36-10 - Open Circuit - Intermittent
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    35-00 - -
  3. Re: ABS Fault - 2003 Passat TDI
    Norfolk
    Check for 12V at the fat red/white wires on the abs unit. Check the fuses again. What warning lights are currently on.
  4. ABS Fault - 2003 Passat TDI
    Aug 2007
    I'll get that voltage checked shortly but as for the warning lights, I have;
    ESP - constant amber
    ABS - constant amber
    then when you drive forward over 6mph the Handbrake light starts flashing red.
    Usually the check pads comes on constant amber but since working on the car today that seems to be staying off.
  5. Re: ABS Fault - 2003 Passat TDI
    Norfolk
    Check the master cylinder brake fluid level for the flashing handbrake warning.
  6. Re: ABS Fault - 2003 Passat TDI
    Dec 2011
    gwynedd
    How old is your battery?
    If your battery voltage drops below a certain voltage you will get both the ESP and ABS warnings on your display readout between the Dials. Mine is a 2002 Passat 130 TDI Sport, done 162k and it has happened to me twice......both times replacing the Battery has cured the problem. How did I find out? Because My dealer in Shrewsbury who was doing my servicing during its first three years told me my original battery was below par and needed replacement and would throw up the faults. Replaced with an identical Varta with 5 year Warranty and exactly the same message came up in June 2011 and new Varta fitted again and faults deleted. No issues since. Believe 12.4 volts is a minimum reading.
    Tip; You can selectively peel off part of the sticker on top or the Varta battery so that you can check battery acid levels an you always could! I buy my Varta from Tayna in North Wales who do EVERY size of battery mail order next day.
  7. ABS Fault - 2003 Passat TDI
    Aug 2007
    Checked the voltage at the large red and white cable, over 12v with the engine running. Checking across the battery terminals 12.2v.
    Bought a new battery from Halfords. Right type according to their guides, wrong physical size. Tried it anyway but it made no difference to the lights. Gonna bench charge the old battery over night and hope that gives a positive result.
    If not any other ideas?
  8. ABS Fault - 2003 Passat TDI
    Aug 2007
    Mind you I still have to check the fuses. Apart from the normal fuse panel on the end of the dash, the fuses under steering wheel and those in the engine compartment (to the outside of the battery) are there any others I need to locate?
  9. Re: ABS Fault - 2003 Passat TDI
    Dec 2011
    gwynedd
    When I replaced my battery in 2006 following the second ABS/ESP fault code displays, replacing the battery cured the problem but still needed to have the fault code display readings deleted. My VCDS was with my son 200 miles away so I had to have them deleted by a local garage costing Ł30 instead of a VW dealer wanting Ł70+ just to plug me in to VAGCOM. Had to pay up and have now bought an Autel hand held reader to be able to read/delete fault codes so that I don't need to fork out Ł30 again. If the fault code doesn't return, the problem is solved. Your reading of 12.2v is a partially charged battery You need 12.4v minimum preferably higher.
    Re Halfords. I was given the wrong battery by Halfords Aberystwyth although their reference said it was correct. That is why I bought Mail Order from TAYNA in North Wales. Good service.
  10. Re: ABS Fault - 2003 Passat TDI
    Aug 2007
    Chipped3
    Nahdah. Tried the old battery having charged it overnight. I Vagcom deleted the error codes but turning the car on again and up came my the two li'l amber nemesis, ABS and ESP lights.
    Took the old battery out, popped the new (but wrong sized one) back in and again Vagcom deleted the codes. Same B|@@&Y lights again. AAAAAAAARGH.
    The worst thing is your solution makes sense though, the old battery is a minimum of 5 years old, probably more, maybe even original as it is a VAG Battery. Now wondering if the New batery is just WRONG!!! no thanks to Halfudds.
    At least the "Check Brake Pads" warning beep has stopped and the check pads light isn't coming on any more. One down 2 and a flasher to go.
  1. Replies: 7
    Last Post: 16-12-2012, 11:46 AM
  2. Please Help 2003 Passat 1.9 TDi Brake and Clutch Problem - ESP and ABS lights on
    By Stuartd77 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2011, 09:20 AM
  3. Passat - ABS Pump Fault 2005 130 TDI Highline Estate
    By feldon in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-03-2010, 09:15 AM
  4. 2003 VW Passat 1.9TDI 130 - ABS/ESP warning light!
    By nick.king in forum Archive posts
    Last Post: 03-02-2008, 07:00 PM
  5. 2003 Passat ABS Fault
    By J warden in forum Archive posts
    Last Post: 14-10-2007, 05:06 PM
