Thread: Tyre Help - Urgent 295/40/21, Can I use them
Results 1 to 9 of 9
  1. Tyre Help - Urgent 295/40/21, Can I use them
    Sep 2012
    Gloucestershire
    Evening all. Got 21's on my new Q7. Tyres were pretty worn and picked up from a friend a set of 21" new Continental CrossContact UHP's for £800 (cost).
    I ordered 295/35/21's but got 295/40/21's so 5% higher sidewall.
    As he has done me a favour and got me these cheaply can I use them or do I need to find someone to swap or sell them?
    Appreciate 5% is not much and it will slightly alter the speedo, apart from a little bit of roll what would be the issues with fitting these?
    They have LOADS of clearance in the arches, the speed rating etc are bob on, I have used these on a RRS and RR Vogue and like them.
    I need to know if I have to go back to him and see if he can swap (and face embarrassment) or simply fit and expect a slightly softer ride.
    Thank Q
  2. Re: Tyre Help - Urgent 295/40/21, Can I use them
    Sep 2012
    Gloucestershire
    forget it - just pulled the tyres from the boot, when standing the wheel up against the arch I think it might be too big.
    Cheers.
  3. Re: Tyre Help - Urgent 295/40/21, Can I use them
    Dec 2010
    Wakefield UK
    Quote Originally Posted by milesg View Post
    Cheers.
    295/40 21 will be fine.
    many use 275/45 20 which are slightly taller still.
    When you held against wheel you probably wasn't taking into account natural compression from weight of car.
    Sorry reply is so late.
  4. Re: Tyre Help - Urgent 295/40/21, Can I use them
    Jul 2011
    Near Uxbridge
    I would beg to differ......sure the 295 40s will fit but as the OP says they are way more than the recommended 2.5% maximum difference in diameter. As to the 275 45 20s, well they are actually smaller than the 295 40 21 not larger. Don't do it.
  5. Re: Tyre Help - Urgent 295/40/21, Can I use them
    Dec 2010
    Wakefield UK
    Quote Originally Posted by neilos100 View Post
    I'm sorry I meant many use 295/45 20 (instead of 275/45 20) and they are fine with absolutely no rubbing.
    Also many many people put 22" on Range Rover Sports with 285/35 22 tyres and this set up is 4.3% bigger.
    The 295/40 21 size is only 1.7% larger than the standard 275/45 20 and the recommended 295/35 21 is 2.2% less than the standard 275/45 20.
  6. Re: Tyre Help - Urgent 295/40/21, Can I use them
    I'm guessing the OP's managed to resolve his urgent query
  7. Re: Tyre Help - Urgent 295/40/21, Can I use them
    Mar 2008
    High Wycombe
    Quote Originally Posted by Eshrules View Post
    If they fitted, they're probably worn out by now.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  8. Re: Tyre Help - Urgent 295/40/21, Can I use them
    Jul 2011
    Near Uxbridge
    Haha...didn't notice. From September last year.
    Sent from my phone...
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  9. Re: Tyre Help - Urgent 295/40/21, Can I use them
    We'll let you off, in fairness to you it wasn't you that necrobumped it;-)
    Sent from my Nexus 7 using Tapatalk 2
  1. Q7 2009 tyre pressure URGENT 275/45/R20
    By timp in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 30-06-2012, 05:43 PM
  2. NEED urgent help
    By KAL audi A6 in forum VCDS - Help Requests
    Last Post: 07-03-2012, 08:10 PM
  3. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  4. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
  5. URGENT HELP .6N X reg Polo Automatic gear issue - Urgent Help please!
    By javednazeer in forum Polo - Derby - Lupo - Fox
    Last Post: 12-03-2008, 08:26 PM
