Thread: VW sharan 1.8T 20v rev overhang on gear changes
  1. Exclamation VW sharan 1.8T 20v rev overhang on gear changes
    Aug 2012
    bury st edmunds
    Hello All, I have an issue with the above beasty, when accelerating and changing gears, the revs do not drop of when letting off throttle, in fact often they increase for a second or so, I have no faults showing on vagcom, have recently replaced the maf with no change to this issue, Had a good look around for air leaks, nothing obvious found (pcv system seems ok), Anyone else had this issue or aware of a possible cause? I am beginning to think throttle body.......
  2. Re: VW sharan 1.8T 20v rev overhang on gear changes
    Aug 2012
    bury st edmunds
    bump
  3. Re: VW sharan 1.8T 20v rev overhang on gear changes
    46 Post(s)
    My old Megane done this - I believe it was a clutch pedal switch going from memory.
  4. Re: VW sharan 1.8T 20v rev overhang on gear changes
    130 Post(s)
    1972 Post(s)
    Yes I would say the clutch pedal switch is faulty. Its operation can be checked in measuring blocks.
  5. Re: VW sharan 1.8T 20v rev overhang on gear changes
    Aug 2012
    bury st edmunds
    Thanks Chris/Crasher, I'll check it out..........
  6. Re: VW sharan 1.8T 20v rev overhang on gear changes
    Aug 2012
    bury st edmunds
    just a refresh to tie things off, checked the clutch switch, no probs there, so had a minor brain wave and checked to see if the recirc valve was dumping, took the vac line off it and found you can suck/blow through it, Diaphragm has gone.........
    fitted a nice shiney new alloy valve, problem solved. Not so easy a task on the Sharan as the valve is accessed from under the car (tray off) and in a fairly tight hole
    bit of a rubbish spot for it, I think I'm going to relocate it up front to just before the throttle body.
  7. Re: VW sharan 1.8T 20v rev overhang on gear changes
    130 Post(s)
    1972 Post(s)
    Don't re-locate it, on the ones I have seen the ECU objects.
  1. Can’t rev TDI above 2500rpm when not in gear
    By a4audio in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-09-2010, 08:48 AM
  2. Please Help 1.8 20V APT gear selection issues
    By johnwintle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-12-2009, 03:12 PM
  3. 20V Turbo idles but struggles to rev
    By blangdal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-06-2009, 01:15 AM
  4. Vw Sharan 1.8t 20v Petrol
    By jamjam12345 in forum Touran - Sharan - Caravelle
    Last Post: 11-12-2007, 02:14 PM
  5. MK4 Golf 1.8 20v N/A (AGN) doesn't rev past 4500rpm
    By mjbrooky in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2007, 12:47 PM
