Thread: Which VAG-COM to get please?
  1. Question Which VAG-COM to get please?
    Aug 2012
    Cheslyn Hay, Staffordshire
    Are the VAG-COM cables and software bundles any good that are offered on eBay? After giving my Mk4 Golf a good clean out (in another thread I asked about emissions) I have got rid of a lot of sludge and muck from the engine breather and cam cover. However, the engine, while pulling a lot smoother, now hunts badly at tick over and frequently cuts out.
    I suspect the throttle body may need to be reset?
    I did use all new gaskets on the inlet manifold and made sure they were in place before tightening them down. Should they have been put in with silicon sealant too? I did not do this I just put them in as they came, dry.
    So, with the above in mind I am willing to get a VAG-COM cable and software but I cannot afford to go to a dealer (would they even sell it?) as I am disabled and on a low fixed income.
    Your anticipated help is most welcome
  2. Which VAG-COM to get please?
    Jul 2012
    Newcastle, United Kingdom
    Hi, I bought this one from Amazon to diagnose my Audi engine codes. Very easy to use and was accurate at diagnosing my engine issues.
    http://www.amazon.co.uk/gp/aw/d/B001...5818097&sr=8-5
    Audi A4 1.8T 2004 B6
  3. Re: Which VAG-COM to get please?
    Oct 2005
    That code reader wont be able to perform a throttle body alignment.
    Buy a cable from Genden (see here) or similar retailer and a copy of VCDS-Lite (see here)
    For what VCDS-Lite can and can't do - see here
  4. Re: Which VAG-COM to get please?
    Aug 2012
    With apologies for appearing to be a bit dense here Am I correct in assuming that what I need is the VCDS-Lite software and that this will be able to perform the throttle body (motor) alignment? I have gone through what it can and can't do but I am left bewildered. It does not specifically mention my need.
    Thank you for the advice so far
  5. Re: Which VAG-COM to get please?
    Oct 2005
    You are correct yes, however the VCDS-Lite software will need to be registered in order for it to perform a throttle body alignment (if that is what needs to be performed of course).
  1. Vag Com in Swindon - moved to VAG-COM forum
    By Alex Himself in forum VCDS - General Questions
    Last Post: 13-08-2015, 10:47 PM
  2. Anybody with Vag-com/Vag-tacho in Midlands area I need you!!!
    By Verygoldgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 11-08-2012, 10:31 PM
  3. Question Should an independent advertising themselves as VAG specialists have VAG-COM
    By barefootin in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 16-07-2009, 06:25 PM
  4. Vag-com & Vag-Tacho
    By rhinopower in forum VCDS - General Questions
    Last Post: 17-03-2008, 01:11 PM
  5. Vag-Tacho using Vag-Com lead?
    By xaindsleena in forum VCDS - General Questions
    Last Post: 11-03-2008, 12:16 AM
