Thread: Steering column fault??? Is this a recall?
Results 1 to 10 of 19
  1. Question Steering column fault??? Is this a recall?
    Jun 2012
    Enniskillen
    I have had my 07 Passat SE 140 now for almost a month...not a bad thing to say about until yesterday, even then it was hard to say. Jumped into the car, put the key in and the dash died. No start, no lights, nothing. Key out, jumped out to check under the hood and see if it was a battery issue. (1st thot). Shut the door and the dash came on. Same thing today but it sounded like the computer was resetting. Clocks back to 0.00, miles left in tank changed to a random 340miles (only filled it the day before.)
    I have been reading up on the forums and some are saying its a recall due to customer complaints. Has anyone come across this and have you got any hints on cause or solution? Thanks. Passat sketch.jpg
  2. Re: Steering column fault??? Is this a recall?
    Norfolk
    Quote Originally Posted by blackdubbin View Post
    The cause is usually wear in the steering lock and the solution is a £300 repair by VW. I have not heard of a recal for this.
  3. Re: Steering column fault??? Is this a recall?
    Jun 2008
    The recall for this is in US not UK
  4. Re: Steering column fault??? Is this a recall?
    Jun 2012
    Enniskillen
    Yeah....i think it was a recall in the US. Which doesnt make sense to me seeing as it seems to be the same common fault. Cheers martin1810 for the cost - going to have to wait till next month!
  5. Re: Steering column fault??? Is this a recall?
    Sep 2008
    SE London
    Get yourself a VCDS scan at least, and post here? Clean and check your battery terminals and connections.
    Hoping it's something simple and not a steering column fault. Good luck
  6. Re: Steering column fault??? Is this a recall?
    Up North
    Unfortunately, the US seems to have better consumer law so things get fixed whereas in the UK we just get fobbed off.
    There was a problem with early DSG gearboxes which resulted in a 10 year, 100k guarantee over there and they have now even offered a 10 year warranty in China! Here in the UK people had to spend their own money and I'm sitting on eggshells after two DSG faults (one out of warranty) until I can chop the car in for something else. I've just coughed up £175 for a problem on the wife's car that was a freebie in the US. The infamous injector problem went on for years here until enough people contacted VOSA to complain they were driving a death trap. The list goes on. I'm betting the next one will be the EPB that Martin spends so much time advising people about.
    Forget the famous VW reliability and any chance of getting an underlying poor design-related fault acknowledged and dealt with. You might as well be driving any make of tin box now.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  7. Re: Steering column fault??? Is this a recall?
    Jun 2008
    spot on teflon unfortunately.
    OP if you get steering column repair done at dealer let us know how it goes please ££wise
  8. Re: Steering column fault??? Is this a recall?
    Norfolk
    This seems to be what the USA got.
    Code: 48I5
    Subject: 2006-2010 Passat/Passat Wagon and 2009-2010 CC/Passat CC
    Electronic Steering Column Lock
    U.S.A.
    2006-2010 Passat/Passat Wagon (Emden)
    WVW_ _ _3C_6E002717 – WVW_ _ _AN_AE058994
    Production date: March 5, 2005 – October 19, 2009
    2006-2010 Passat/Passat Wagon (Mosel)
    WVW_ _ _3C_6P005115 – WVW_ _ _AN_AP022099
    Production date: June 1, 2005 – October 17, 2009
    2009-2010 CC (Emden)
    WVW_ _ _3C_9E502245 – WVW_ _ _AN_AE526509
    Production date: May 20, 2008 – October 19, 2009
  9. Re: Steering column fault??? Is this a recall?
    Jun 2012
    Enniskillen
    Well no errors showing on scan....service completed with the VW dealership with the following results:
    - Battery required
    - alternator required
    - ignition relay required
    I have since purchased a new 780A Bosch battery (upgraded the 540A original) and tested the alternator. Alternator test passed, therefore I dont understand why they would tell me its faulty.
    No problems starting, but going back in to get the ignition relay changed. Unless someone can tell me where to get one? I will change it myself.
    Thanks for the comments, and i will keep yous informed. Oh...and they quoted my £50-£60 for the Steering Column switch, and a further £250-£300 to fit it. But that was prior to the service, so obviously they feel the ignition relay will solve that infrequent issue.
  10. Re: Steering column fault??? Is this a recall?
    Norfolk
    I doubt you needed a battery, alternator or an ignition relay. I still think you have the early signs of steering lock failure. As garage said it's about £60 for the part and £250 to fit and code it.
    The terminal 15 (ignition) relay costs about £10 and fits above the drivers knees...sort of. I suspect that you will still be having the steering lock repaired in the future.
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Steering Column fault - question before approaching dealer
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2012, 10:36 AM
  3. electric adjustable steering column fault
    By allroadkev in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 06-12-2010, 10:13 PM
  4. Adjustable steering column fault
    By SNELL739 in forum A8 - S8 - V8
    Last Post: 18-01-2010, 06:56 PM
  5. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
