Thread: Audi 1.9 TDI 115 B5 shaking
Results 1 to 8 of 8
  1. Audi 1.9 TDI 115 B5 shaking
    Aug 2012
    Hereford
    My W reg 1.9TDI 115 has started to intermittently shake whilst idling but only in warmer weather. It disappears when i dip the accelerator though. I have had the clutch and DMF done about 800miles ago so it isnt that. I have noticed that my temperature gauge doesn't sit still and slowly goes up and down, but it never goes above 90. Would this be related?
    Anyone got any ideas??
    thankyou
  2. Re: Audi 1.9 TDI 115 B5 shaking
    Aug 2012
    Hereford
    anyone??
  3. Re: Audi 1.9 TDI 115 B5 shaking
    Dec 2007
    8 Post(s)
    Quote Originally Posted by leohufc View Post
    anyone??
    Its possible that it may be fuel pump related issue
    Regards
    Michael
  4. Re: Audi 1.9 TDI 115 B5 shaking
    Aug 2012
    Hereford
    thanks for the reply,
    what makes you think it could be this?
  5. Re: Audi 1.9 TDI 115 B5 shaking
    Dec 2007
    8 Post(s)
    I owned a few audi 80 tdi,s that suffered from a hunting idle
    the problem was in the fuel pump.
    It may be possible your problem could be similar.
    Regards
    Michael
  6. Re: Audi 1.9 TDI 115 B5 shaking
    Jun 2011
    chester
    Hi I've got the same Audi as you the 115bhp.
    Now when I bought mine temperature gauge was doing the same as yours. The thermostat is simply faulty. After replacing it from using eurocarparts, it failed a week a later. So I bought one of the main dealer I think it was a tenner, fine since. I would advise getting the main dealer one. Also it has increased my mpg by like 10-20 % as the engine was always trying to warm itself up so it used more fuel.
    But please let me know about the rough idle if you find any solution to it. Mine also does that once in a blue moon.
  7. Re: Audi 1.9 TDI 115 B5 shaking
    Dec 2011
    Bradford
    I have a 99 avant 110 tdi AFN which has exactly the same problem. When the weather is above 19/20 dedrees the engine shakes at idle speed, a quick blip of the throttle temporally cures it. The car runs perfectly in cooler weather.
    i would love to get to the bottom of it, my garage who normally can sort out hard to fix problems is at a loss.
  8. Re: Audi 1.9 TDI 115 B5 shaking
    london/ UK
    The PD 115 is completely different to the AFN VE engine, the only thing they share is the block. With the PD engine the injector wiring loom is a known failure, take the rocker cover off and replace the loom- it's about 50 quid at the dealer and they do keep it in stock ! Whilst the rocker cover is off check the cam lobes for wear, the pd engine is very particular on oil quality and will munch the cam and lifters if improper grade used.
    The AFN is much more robust and does not care about oil grade, the cam can withstand a nuclear blast and rocker needs replacing after 200-300 k. Rough iddle in these models can be due to:
    -worn DMF, will manifest when hot
    -worn quantity adjuster/Fuel temp.sensor
    -improper setting/timing of the injector pump
    -duff coolant temp sensor
    -duff MAF
    The AJM/ATJ pd 115 engine can missfire due to:
    -Worn FMF
    -improper timing/setting of the camshaft angle
    -duff CTS or MAF
    -duff injector wiring loom
    -worn injectors
    In both cases a diagnostic scan may shed some light over the real cause...
  1. Question a shaking audi a4 tdi?
    By lee a4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2012, 07:23 PM
  2. I need a new Altenator for Audi A4 1.9 TDI 115 2000 (W)
    By Bryden Leask in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-05-2010, 12:25 AM
  3. Audi A4 TDI 115 Power drop
    Last Post: 04-03-2010, 10:46 AM
  4. Question audi a4 115 tdi 2004
    By arman123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-01-2009, 06:04 PM
  5. Smoking Audi A4 Avant 1.9 TDi 115
    By parmaham in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-12-2006, 05:40 PM
