Thread: 20 inch wheels on Audi A6
  1. 20 inch wheels on Audi A6
    Aug 2012
    Leicestershire
    Hi guys
    New to the forum as I'm not (yet) an Audi owner.
    I'm currently looking for a 2009/10 A6. It has to be diesel and would probably be the 2.0 possibly the 2.7. Has to be an s line too.
    If I find one with the Le Mans 19s then I would probably stick with these however if it has the 18s then I'd be keen to upgrade and love the idea of 20s as I think the A6 is a big enough car to pull off 20s without looking silly.
    I'd only go for Audi replica style alloys to try and keep it looking factoryish.
    My question is what size wheels (I.e. width) would I need. I definitely wouldn't want the wheels protruding out and being wider than the body.
    Also, I would want to fit some lowering springs. Don't want it slammed just want to eliminate any big gaps between arches and tyres.
    Any advice anyone could provide would be much appreciated.
    Cheers.
  2. 20 inch wheels on Audi A6
    46 Post(s)
    Welcome to VWAF
    I have no idea on numbers but you have the same initials as me
    The RS6 comes with 20's as standard so it is possible.
    Good luck!
  3. Re: 20 inch wheels on Audi A6
    Sep 2011
    Lurking over a keyboard ...
    You may need narrower alloys than a RS6... as that has outwards wider arches... hope that make sense
  4. Re: 20 inch wheels on Audi A6
    Aug 2012
    Leicestershire
    Welcome to VWAF
    Good luck!
    Same initials and I'm a Chris too!
    Hard to compare to the rs6 as it has the flared arches although I don't think the rs6 20s are overly wide they are just spaced further out.
    I believe the le mans 19s are 8.5 inches wide so as long as 20s were the same width I guess they would fit easy as long as tyres were very low profile. (which I know will give a harsh ride but I'm ok with this)
    Thanks for the advice.
  5. Re: 20 inch wheels on Audi A6
    Jul 2012
    Stoke
    I have 255/35r19 on 19x8.5j et43 wheels and if you can get a wheel with 255/30r20 of similar offset (somewhere between 8.5" and 9.5" width) then it will have identical dimensions. Mine is a standard 2.7 A6 and has plenty of clearance, not sticking out at all beond the arches. In fact I could have gone for less offset (10mm probably) without any issues.
  6. Re: 20 inch wheels on Audi A6
    May 2012
    essex
    I looked into 20 reps on my le mans, 9 x 20 et 45 with 255/30/20 is spot on. 1 of my friends works at audi & his company is an a6 with the option 20's on it & they look stunning & don't give a bad ride either.
    Sent from my GT-I9000 using Tapatalk 2
    2007 3.0 tdi le mans : Hybrid turbo decat : miltek etc : 330-350 bhp : 450-500lbsft
    Visibility pack. Adaptive xenon, Privacy glass. Bose surround. Dvd nav. Comms pack, led plate lights.
    Miltek, custom map,hybrid turbo, decat improved airflow to intercoolers.
  7. Re: 20 inch wheels on Audi A6
    Aug 2012
    Leicestershire
    Thanks for all the advice guys.
    Just put down a deposit on a 2010 A6 2.0 tdi (170) le mans with the 19s fitted so doubt I'll be going for 20s.
    Chris
    1 2 0
  1. Fabia VRS wheels. 17 inch.
    By John1525 in forum Touran - Sharan - Caravelle
    Last Post: 07-08-2012, 10:12 PM
  2. 18 inch wheels
    By petor in forum Audi A3 - Archive Topics
    Last Post: 27-10-2008, 11:44 PM
  3. 19 inch RS6 Wheels
    By shane9new in forum Golf MK4 - 1999 - 2004
    Last Post: 06-06-2008, 09:03 PM
  4. Fitting 19 inch wheels to Audi b6 Avant
    By jonzolee in forum Chat - Anything with wheels
    Last Post: 27-04-2008, 02:20 PM
