Thread: power steering pump and location of fluid
Results 1 to 10 of 11
  1. power steering pump and location of fluid
    Jul 2012
    manchester
    hi guys i have a audi a3 2.0 tdi 2004 the power steering lights is on the dash the orange steering wheel and the steerin feels a tad heavy icant for the life of me find the fluid resivior location any help will be good for me thanks
  2. Re: power steering pump and location of fluid
    Pembrokeshire
    22 Post(s)
    if its anything like the fabia i have just done with the same problem, its under the battery tray but just visible between it and the wing. this one was pretty empty.
  3. Re: power steering pump and location of fluid
    wakefield
    Think you'll find its electric so doesn't have a pump,will need plugging into diagnostix.
  4. Re: power steering pump and location of fluid
    Pembrokeshire
    22 Post(s)
    hmm, not sure, but i think its the same as the fabia, which is electric, but is a conventional hydraulic system with an electric pump rather than belt driven pump. low oil level, air in system, low pressure, warning light comes on.
  5. Re: power steering pump and location of fluid
    Dec 2011
    Richmond
    6 Post(s)
    It's electromechanical power steering. No fluid, electric motor on the steering rack.
    Southern County Softy
    20 Post(s)
    As vikingraider says it's electromech.
    Get a fault scan and see if you can clear the fault.
    I had to change the rack on my daughters A3 for a pump fault.
    follow me on twitter...kiteaudi...
    A4 2.5 tdi QS (mapped)
  7. Re: power steering pump and location of fluid
    Jul 2012
    manchester
    cheers guys the oil preure light is on aswell also the brake lights are on do you guys think this as anything to do with it
    20 Post(s)
    Get the car scanned for faults.
    Brake light switch could of failed.
    Is it oil pressure or oil level light on
    Is it amber or red?
  9. Re: power steering pump and location of fluid
    Jul 2012
    manchester
    hi mate yeh ive just had the brake switch done but my mate hasnt had chance to clear the codes yet, its a red oil presure light whats the diffence between the red and the amber light? and i hear these brake switch can cause some problems at first my accelerator wasnt workin until i got it fixed
    20 Post(s)
    Red light is low pressure, amber light is low level.
    I wide not drive the car until the pressure is checked.
    It could be a faulty pressure switch
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Question Power steering fluid
    By golligy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-01-2011, 09:20 PM
  3. Question Location of Power Steering FLuid Reservoir
    By xptomaria in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-01-2010, 04:57 PM
  4. Power Steering Fluid
    By Jblion in forum Archive posts
    Last Post: 02-10-2007, 08:35 AM
  5. power steering fluid?
    By markcass in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-03-2007, 10:45 PM
