Thread: ALT engine intake manifold help
Results 1 to 10 of 17
  1. ALT engine intake manifold help
    Aug 2012
    Ecuador
    Hello. i have a a4 b6 2002 with ALT engine 2.0 manual trans. I have searched but i cant find much info about the ALT engine. right now all the vacuum and coolant hoses are disconnected cause i took the intake manifold for replacement cause of a crack in it. i need a diagram, diy or some pictures to put all the stuff together again.
    thank you very much
  2. Re: ALT engine intake manifold help
    130 Post(s)
    1972 Post(s)
    As it is a simple system there does not appear to be a diagram on the workshop information system.
  3. Re: ALT engine intake manifold help
    Aug 2012
    Ecuador
    maybe some vacuum, intake, coolant parts diagram from etka?
  4. Re: ALT engine intake manifold help
    130 Post(s)
    1972 Post(s)
    We are not allowed to post big sections like that, not really even the little snipts that we do but we don't want to push our luck.The ETKA diagram for the ALT coolant hoses and vacuum lines is of little use anyway.
  5. Re: ALT engine intake manifold help
    Aug 2012
    Ecuador
    thank you. ill post pics of the parts i dont know where to connect
  6. Re: ALT engine intake manifold help
    Sep 2011
    Shannon, Ireland
    Hi. My B6 have an ALT engine. Do post picture, I'll try to help if I can
    2001 Audi A4 2.0 20V
    1995 VW Polo 1.05-sold
    Mod's so far: cruise control and DIS retrofitted, two cup holders in dash
    Mod's to come: ESP switch and card holder relocation, color DIS, extra lighting
  7. Re: ALT engine intake manifold help
    Aug 2012
    Ecuador
    Quote Originally Posted by RuslanA4 View Post
    Thank you Ruslan, please i need you to check your coolant temp sensor wires and tell me which color goes into which pin. my pigtail broke and i need to connect directly the wires to the pins
  8. Re: ALT engine intake manifold help
    Jan 2009
    Birmingham
    36 Post(s)
    here you go
  9. Re: ALT engine intake manifold help
    Aug 2012
    Ecuador
    Thank you. now i need desperately that you help me with the wire colors and pinout of the coolant temp sensor of the ALT engine. cant find that and need to connect each wire to the correct pins
  10. Re: ALT engine intake manifold help
    Jan 2009
    Birmingham
    36 Post(s)
    what colour are the four wires
  1. Question Intake manifold need replacing??
    By Bethj in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-04-2014, 03:04 PM
  2. Intake Manifold Runners ... Again!!
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-02-2012, 02:21 PM
  3. Question intake manifold pressure
    By geo_855 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-04-2011, 12:47 PM
  4. Engine oil around intake manifold.
    By b1llyb0y in forum Golf MK5 - 2004 - 2009
    Last Post: 06-07-2010, 08:56 PM
  5. Intake Manifold ???
    By Bandooli in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2008, 11:50 PM
