Thread: Ebs warning light on
  1. Ebs warning light on
    Jan 2012
    Uddingston
    Folks
    The EBS warning light on my 2006 A3 2.0 tdi has came on, brakes and everything feel fine although I could be needing new pads, tried switching it on and off using the switch on the dash, tried turning engine on and off as hand book suggests. Any ideas or obvious problems before surgery
  2. Re: Ebs warning light on
    46 Post(s)
    You need a fault code scan done.
    Do you have a DIS?
    If you dont, you may have a brake light or similar blown.
    A scan is most crucial here to diagnose the correct fault.
  3. Re: Ebs warning light on
    Jan 2012
    Uddingston
    Thanks Chris
    My mistake though its the ESP light electronic stabilisation program.
    Any ideas
  4. Re: Ebs warning light on
    46 Post(s)
    Still need the fault code scan done to pinpoint the problem
    Have a look here (VCDS - Users Locations) for people in your area.
  1. Please Help Flashing Engine Light & Constant Exhaust Warning Light
    By Tups1974 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-04-2012, 08:23 AM
  2. Boot Light, Washer Bottle Warning Lamp, Glovebox Light,
    By jonathanfenton in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2008, 10:26 PM
  3. Air bag warning light, Brake warning light
    By michaelboyd49 in forum 80 - 90
    Last Post: 30-11-2007, 09:50 PM
  4. ebs warning light.
    By w-s-m passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-06-2007, 05:20 PM
  5. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
