Thread: a3 tdi removed battery and now will not start
Results 1 to 10 of 17
  1. a3 tdi removed battery and now will not start
    Jul 2012
    manchester
    hi guys i have a audi a3 2.0tdi 2004 had a flat batery removed and recharched 3 times on the 3rd time car would not start or even crank think imobaliser is stuck on any ideas guys
  2. Re: a3 tdi removed battery and now will not start
    Apr 2007
    France
    Lance, first try a different battery. Also check the battery grounding cable, and of course both terminals and clean off any corrosion. Your battery should not have gone flat, unless the car had not been used for many months. A faulty or old battery will go flat by itself very quickly. There also may be an electrical issue with your A3, so get that checked out too. Good luck.
  3. Re: a3 tdi removed battery and now will not start
    Jul 2012
    manchester
    Quote Originally Posted by Geraldy212 View Post
    hi mate yeh its a new battery and the old one was knacker also ive checked all connection all ok . ive had it working with new battery just not drove it for 2 month as i been workin away and now it seems since i charged the battery the imobaliser stuck on or maybe it has been activate due to battery being reoved
  4. Re: a3 tdi removed battery and now will not start
    Jan 2012
    Coding Something
    IMMO has static programming, it doesnt lose the ability unless the system has a fault, does the car start for 5 seconds then turn of by itself or not even start?
  5. Re: a3 tdi removed battery and now will not start
    Jul 2012
    manchester
    yes mate its starts for a couple of seconds then cuts out but if i try it a few times it is just blank cheers for help
  6. Re: a3 tdi removed battery and now will not start
    Jan 2012
    Coding Something
    That sounds like immo or key at fault, but need to get it scanned to ascertain the issue.
  7. Re: a3 tdi removed battery and now will not start
    Dec 2011
    Richmond
    6 Post(s)
    Quote Originally Posted by lance h View Post
    If it's not even cranking then it's certainly not an immobiliser issue. Probably starter motor if the battery is okay.
  8. Re: a3 tdi removed battery and now will not start
    Dec 2011
    Richmond
    6 Post(s)
    Then again, it seems like it's starting now, then cutting out....
  9. Re: a3 tdi removed battery and now will not start
    Jul 2012
    manchester
    hi guts cheers for replys yeh the problem is it starts then cuts out after a couple of seconds, i have rung a few diffrent auto locksmiths and all of them seem to think the key needs recodin, or th ecu is spiked anybody know anythin about this
  10. Re: a3 tdi removed battery and now will not start
    Jan 2012
    Coding Something
    When you turn ignition on but dont start the car, do you see a flashing yellow/red icon in the cluster?
    How many keys do you have?
  1. Shorted battery by accident now car won't start - battery is good...
    By Nookster in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2011, 06:32 PM
  2. 1.9 TDI battery ran flat now won't start
    By browser1 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-11-2010, 10:06 PM
  3. Please Help My 1.9 TDI won't start...Just a clicking noise, and the battery is fine.
    By soulysurfer in forum Golf MK3 - 1993 - 1999
    Last Post: 16-06-2010, 12:03 PM
  4. Removed dash clocks to repair now have immo light and wont start!
    By mpk490p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-09-2009, 09:17 PM
  5. Question Lock car with battery removed
    By tonyp1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-11-2008, 01:05 AM
