Thread: Alhambra Power Steering
  1. Alhambra Power Steering
    Feb 2012
    Gosport
    Hi anyone know where the power steering reservoir is located. I've started to get a noise when turning the wheel while stationary and want to check the fluid level.
    Stuart
  2. Re: Alhambra Power Steering
    129 Post(s)
    1972 Post(s)
    Down on the cars left next to the battery.
  3. Re: Alhambra Power Steering
    Feb 2011
    Scunthorpe, England
    I had a noise like yours and it turned out to be the alternator pulley. It has a one way bearing in it which siezes up. To answer your question the resevoir on my 2004 model is next to the windscreen washer filler - it has a green cap
  4. Re: Alhambra Power Steering
    129 Post(s)
    1972 Post(s)
    Yes that a good point, get someone to turn the steering from lock to lock and observe the belt tensioner, if it is jumping around excessively then it is likely that the pulley is seized internally.
  1. Alhambra intermittent lack of power
    By jugs1960 in forum Alhambra
    Last Post: 30-08-2012, 09:46 PM
  2. Please Help 6N1 Polo leak in power steering pipe from pump to steering rack
    By crauch6 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2012, 08:36 AM
  3. alhambra sunroof power drain.
    By jonleek73 in forum New Member Introductions
    Last Post: 30-05-2010, 01:17 PM
  4. Alhambra power boost?
    By Alfaman in forum Alhambra
    Last Post: 28-06-2007, 08:45 AM
  5. Seat Alhambra 130tdi power loss
    By notwenam in forum Touran - Sharan - Caravelle
    Last Post: 29-12-2006, 12:51 PM
