Thread: Footwell lights stopped working
  1. Footwell lights stopped working
    Apr 2011
    Norwich
    Hello,
    I changed the bulb in the passenger footwell light this morning. After gently prising the unit from under the dashboard (light still working at this point), I unplugged the holder power supply and then changed the bulb over and put back together again. For some reason the passenger and driver footwell lights are no longer working. I then put the old bulb back in and no joy. The glovebox light is OK, the door lights (red) are OK, but the under door lights (white) are also not working.
    I checked the interior light fuse and the front door fuse, they are both fine.
    Has anyone any thoughts as to why changing a bulb could have caused this and how i can go about fixing.
    Thank you very much
    Mark
  2. Re: Footwell lights stopped working
    46 Post(s)
    No idea, try disconnecting the battery for 30 mins or so and see if the lights come on again
    Unless as you disconnected the light as they were on, you have caused a fault to be logged and this needs cleared before they will function again - I noticed this on my a6, the exact same scenario as you (albeit the number plate light), lights on, took bulb out, new unit in, wont work, fault logged, cleared and now working.
    1 1 0
  3. Re: Footwell lights stopped working
    Apr 2011
    Norwich
    I have seen your posts on the light changes that you have made, they look great.
    I have put a request in to the VCDS forum to see if there is anyone that would be able to help me scan for fault codes etc.
    If not I will try our local friendly garage this week to see if they can sort the problem.
    I will post back my findings
    Mark
    1 1 0
  4. Re: Footwell lights stopped working
    Apr 2011
    Norwich
    Managed to get the car scanned for faults, apparently there were 2 faults in one area, 1 in another. All have been cleared.
    Lights now work perfectly
  1. Please Help All interior lights and door lights stopped working in my Sharan 1.9 TDi (Nov 01 New Shape)
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 09-01-2013, 01:50 AM
  2. Lights-On Alarm stopped working????
    By Strummer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-12-2010, 09:25 PM
  3. Brake and indicator lights stopped working.
    By James paul 74 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-07-2010, 12:09 AM
  4. Warning buzzer (lights on) stopped working
    By tatham in forum Early Passat Forum - Pre 97
    Last Post: 21-10-2008, 08:34 PM
  5. Please Help Wipers and Fog lights stopped working
    By shuggy1001 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-08-2008, 10:01 AM
